-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   need some help on fluid's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/207880-need-some-help-fluids.html)
evilevo2006 Jun 22, 2006 06:34 PM
hi everyone and happy early 4th. im at 36k on my 2003 evo 8. i know i need to change my trans, t case, and rear diff. what else should i change??. i want to use oem fluids. what is used from the factory. also is there a how to on changing everything. if so i couldent find it maby you could help. if not could you give me an idea on what to do. thanks alot. and drive safly.
EvoDan2004 Jun 22, 2006 06:53 PM
bump for response. im at 40k. lol. hope it ant to late.
EvoDan2004 Jun 22, 2006 07:21 PM
well i did a seach and cant find a how to. i found fluids but it was telling you to use redline. id want eom as well.
glgz Jun 22, 2006 07:48 PM
Here is a link to tell you how to change the fluids. I would say to use Diaqueen from Mitsu instead of Redline in the rear diff and transfer case. https://www.evolutionm.net/forums/sh...ad.php?t=75589
Here is another useful link
http://www.evomoto.com/index_tech.php?tPath=2
Also alot of people like to use BG Syncomesh for the tranny from what I heard. I hope this helps.
evo150 Jun 23, 2006 01:38 AM
i followed the same links glgz posted when i changed mine out. i went with diaqueen for the tc and rear diff. and amsoil for the tranny.
