HKS 280's to GSC S1's for Evogreen
Well guys, i'm in a crossroads right now. All the mods for my Evogreen are in my sig, but i've been contemplating to switch my cams out for the S1's. The turbo feels like it takes a little longer to spool up w/the 280's and thats what i was expecting, but not this bad. My 2nd gear pulls feel totally weak, but my 3rd gear pulls feel just fine. This was all done to attempt to log w/evoscan but the laptop didn't have all the updates for it to run dammit. Haha, anyways so what do you guys think? Is it worth it to swap out the cams? I've gotta buyer already setup for the 280's if i decide to take them out and it covers the price for the S1'S. But on another note, would S2's be overkill w/the Green? I've been reading S1's are the perfect cam for this particular turbo. Going to run the track w/my current setup hopefully this week to see where i'm at. {thumbup}
If you want to improve spoolup you might wanna try adjusting your cam gears to +1i/-1e, or the alternate +2i/0e setting. Also, add some more preload to your WG. About 17# is good.
Currently, the S1's seem to be the preferred mild cam grind, and if I was in the market for a new set of cams for my Green-equipped car, that's probably what I would get. But, since you already have HKS 280's installed, then you might as well tinker with them a bit to see if you can get it to spool any better, before going through the expense and hassle of R&R. I have my HKS 280/272 equipped, EvoGreen-fitted RS spooling tolerably well. It isn't quite the same as the old TME, but it is close. I can get it to hit 18.5# by 3600 RPM when I roll it on from 2500RPM. This is with a stock, plastic DV to boot and the cams set at +1/-1. So, you may wanna play around with your setup first. I think that with the right camgear settings you can get your existing cams to work pretty well with the Green. Don't forget that you should have more topend power with the 280's. |
which gear?
Originally Posted by sparky
(Post 4349206)
Keep the HKS's, GSC's are problems{thumbup}
talk to your tuner. leaning out pre boost area will cause your turbo to spool better
^^ all valid points, definite tune adjustment to get that bad boy moving...2nd gear should pull and feel just as good as 3rd...I'm leaning more towards getting your tune tweaked. Leaner spool up or more timing like stated above, I think Jestr knows about that =)...he should be able to adjust your map.
Originally Posted by vwjeff
(Post 4349661)
(Post 4349661)
Wael |
Originally Posted by Bosshog
(Post 4349636)
which gear?
I think there is room for improvement. My car is pig rich as I installed bigger injectors and although the ECU is scaled it is running way rich because I am awaiting an O2 sensor/cable replacement. So, it isnīt tuned at all. Just way rich. Some of the other guys mentioned that pulling fuel at low RPMīs will also improve spool. This and pulling timing at low RPMīs to create more exhaust heat/energy should also help spoolup. Itīs just my opinion that maybe the O.P. should tinker with his present setup and exhaust all the usual tricks before giving up on his HKS 280īs, rather than just spending more cash and wasting a bunch of time switching cams. Furthermore, I donīt think that anyone has yet done any back-to-back dyno tests with the EvoGreen(maybe Iīm wrong) comparing the HKS 280īs vs. the GSC S1īs. Given a set of camgears the 280īs can probably be made to spool almost as well as the S1īs, and the topend should ultimately be better. |
In spite of the fact that Iīve been using HKS 280īs for a couple years; if I had to purchase cams today, I would probably get the GSC S1īs or a GSC 272/264 combo. Itīs just that for me itīs not worth it to spend more money on a new set of cams at this point in time( Iīm saving up my allowance for an Aquamist kit). So, at least for the immediate future, I am destined to tinker with my current setup.
I really like the specs on the S1īs and the fact that they seem to be designed with the stock unported head, quick spool and midrange torque in mind. I like the shorter duration and increased exhaust lift. It seems like a good option for stock to medium sized turbo Evos. |
Originally Posted by Waz996
(Post 4349958)
not fair to bash out with no relevant support.. i havent read a bad review of the GSC cams anywhere. I've been in an Evo with the S1's and they're more than impressive, car is running great not a single flaw.
Wael We have experienced problems with Compcams and Helix quality control. |
(Post 4349206)
(Post 4349661)
(Post 4349661)
Originally Posted by Jspec EVO VIII
(Post 4349177)
maybe your a torque junky & didnt realize it? i had hks 272I/264E & 280/280, see my link below showing the dyno compare. What the dyno chart doesnt reveal, is the transient response experience on the street, everyday! i too am a torque junky too. although the 280's accelerated the car a hell of a lot faster from 60-80 & 40-90, i still prefered the 272i/264e combo. i guess that is the difference between poeple who prefer a 35r over a 30r type turbo. sell the 280's & get the gsc s1's when they're available. |
| All times are GMT -7. The time now is 01:31 AM. |
