HKS Reloaded vs. HKS RS Filter Replacement
I have the regular hks rs intake and when i want to switch the filter, because of the tight fit, i have to dissassemble everything but my friend has the hks reloaded and he can just take the filter part off and change the filter
is the charge pipe or the filter a different size between the two? or is this just with my rs. thanks! |
according to HKS USA, the inlet size is 100mm and the element size is 200mm. both the new RS and RS reloaded AND SMF and SMF reloaded are the same size. but the filter surface offer 30% more surface area for the new reloaded kit.
which reloaded kit does your friend have? smf reloaded or RS reloaded? I am thinking about getting the HKS intake too, what kind of performace gain do you feel the most? thx |
Originally Posted by fugiwara
(Post 4945013)
+1
filter
HKS rs is a great intake. But definitely needs to be tuned to make good power.
any answers to my question?
HKS RS makes power but also lean out the AFR
