- - Avid Motor Mounts
(https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/316574-avid-motor-mounts.html)
awboostjunkie
Jan 3, 2008 06:22 PM
Avid Motor Mounts
Are the avid rear motor and tranny mounts still garbage or have they fixed the problems with these? I've got a set sitting here and I'm going to return them if they haven't fixed it.
7oey
Jan 5, 2008 02:53 PM
Not too sure but I think that they took the mounts for the evo off their website. That idicates to me that these are the same type that broke on the GSC evo.
Erik@MIL.SPEC
Jan 5, 2008 10:58 PM
Now I know why I thought the front mount sucked on my car. It's because they sucked.
awboostjunkie
Jan 6, 2008 08:20 PM
lancer shop still sells them so that's why i was asking
7oey
Jan 7, 2008 03:44 PM
Try to call GSC
Erik@MIL.SPEC
Jan 7, 2008 09:16 PM
Originally Posted by awboostjunkie
(Post 5126474)
In my opinion the Avid front mount (the one I own) is mediocre. Instead of a hole to put the bolt in, Avid has (for the size of the bolt used) a fairly wide cut slot. There is not much surface area for the head of the bolt to seat on, so you'll need a washer (that isn't on the OEM piece). If you just put the mount on there without a washer (like I did), you'll find, over time, the bolt becomes misaligned and doesn't seat properly. This could cause major problems, especially if racing your car (i.e. the bolt breaks).
