Avid Motor Mounts
Old Jan 3, 2008 | 06:22 PM
awboostjunkie's Avatar
Avid Motor Mounts
Are the avid rear motor and tranny mounts still garbage or have they fixed the problems with these? I've got a set sitting here and I'm going to return them if they haven't fixed it.
Old Jan 5, 2008 | 02:53 PM
7oey's Avatar
Not too sure but I think that they took the mounts for the evo off their website. That idicates to me that these are the same type that broke on the GSC evo.
Old Jan 5, 2008 | 10:58 PM
Erik@MIL.SPEC's Avatar
Now I know why I thought the front mount sucked on my car. It's because they sucked.
Old Jan 6, 2008 | 08:20 PM
lancer shop still sells them so that's why i was asking
Old Jan 7, 2008 | 03:44 PM
7oey's Avatar
Try to call GSC
Old Jan 7, 2008 | 09:16 PM
In my opinion the Avid front mount (the one I own) is mediocre. Instead of a hole to put the bolt in, Avid has (for the size of the bolt used) a fairly wide cut slot. There is not much surface area for the head of the bolt to seat on, so you'll need a washer (that isn't on the OEM piece). If you just put the mount on there without a washer (like I did), you'll find, over time, the bolt becomes misaligned and doesn't seat properly. This could cause major problems, especially if racing your car (i.e. the bolt breaks).
OhioWhiteEvo8
Jan 25, 2014 08:51 AM
escodotcarter
Nov 23, 2010 08:05 PM
omniprobe
Oct 21, 2009 06:59 PM
