Inside my lightly cooked tranny
2 Attachment(s)
Ran out of fluid on the highway and locked in 5th gear.
Opened her up today. I will need AT LEAST: New 3rd, 4th, 5th, Rev gears/sleeves/synchros and bearings. https://www.evolutionm.net/forums/at...8&d=1205854490 https://www.evolutionm.net/forums/at...7&d=1205854472 |
What happened?
Hope you get it fixed soon!!! |
Looks to be more like medium or medium well :0
John |
he said he ran out of fluid
That sucks shameless. What are your plans, rebuild to stock?
Originally Posted by MR Turco
(Post 5424370)
I may opt to get a new one from Shep if the rebuild exceeds $1500. |
Originally Posted by jshepherd
(Post 5424280)
John |
Originally Posted by ShamelessCookie
(Post 5424379)
I'm still weighing the options... I will either rebuild it myself with Evo 8 3rd-4th, but I'm not sure if the countershaft is usable... it could become a very expensive rebuild.
how long was your trannsmission leaking?
Mine was alot worse. I messed up my 3-4 shift fork, cracked 4th gear, 2nd gear grind, 3rd grind, and 5th had no teeth on the gear. All from slaming my gears in while drag racing my car. When racing I would get locked out of gear but I would just force it in. The shift fork broke on me when I was doing a run vs another Evo.
Got the whole trans rebuilt by Adam at Devo Tuning. I must say he did a great job. Also he hooked me up cheap for the Evo VIII 4th gear. |
Hey, look at it this way, at least you did it right the first time.
Originally Posted by DonHugo
(Post 5424409)
I refilled it and the next day it locked up in 5th. Bummer :mad: |
The shaft is no good... gears and sychros look really really bad from the inside.
Ordered a Shep w/ Evo 8 gears and Double Synchro 5th. Hopefully I can make it to opening weekend at the drag strip. Any idea what Shep recommends for fluid? I forgot to ask. |
Redline MT90 is what he told me to use.
good luck with your situation. I'm sur you learned your lesson, when I did my clutch I actually thought of leaking situation so when everything was installed I started the car for a few minute and let it sit in a clean floor(garage) to check for leaks and so.
