Check engine light
can someone tell me how to turn the check engine light off. 2003 VIII. I have a plugin for resetting error codes but it does not work for resetting the check engine light
disconnect negative to battery for a few minutes maybe.
What errors are you getting?
do you have taktrix
Go to your local auto parts store and check out their OBD-II scanner. Read what the codes are and then reset them from the tool.
Autozone for free, or if you have tactrix cable you can use EVOscan or OBDII software to scan and reset codes...
Originally Posted by jonjon123
(Post 6216365)
Originally Posted by Fast_Freddie
(Post 6216795)
turn key 4 times without starting the car , then start ur car ...
Originally Posted by fevo
(Post 6216957)
got it fixed thanks guys
(Post 6217059)
Originally Posted by DJ Brett B
(Post 6216973)
Really? This will clear the code? I have not ever heard of this... are you sure?
^ I didnt think it would, it sounded like bs to me!
sure BS ...
I wouldnt care .. I save 1 trip to dealer yesterday read it from somewhere hopeful my SES wont comes on again , coz I have battery back up type alarm , if i disconnect battery , it will make noise it works for me only , =P |
