Check engine light
Old Oct 10, 2008 | 09:52 AM
jonjon123's Avatar
Check engine light
can someone tell me how to turn the check engine light off. 2003 VIII. I have a plugin for resetting error codes but it does not work for resetting the check engine light
Old Oct 10, 2008 | 09:57 AM
diiirk@AwdMotorsports's Avatar
disconnect negative to battery for a few minutes maybe.
Old Oct 10, 2008 | 10:06 AM
Tnnrx7's Avatar
What errors are you getting?
Old Oct 10, 2008 | 10:08 AM
sharkm87's Avatar
do you have taktrix
Old Oct 10, 2008 | 11:14 AM
mrMTB's Avatar
Go to your local auto parts store and check out their OBD-II scanner. Read what the codes are and then reset them from the tool.
Old Oct 10, 2008 | 11:20 AM
Fast_Freddie's Avatar
Veteran: Navy
Autozone for free, or if you have tactrix cable you can use EVOscan or OBDII software to scan and reset codes...
Old Oct 10, 2008 | 11:29 AM
rcheung's Avatar
If you erase the codes the cel will erase too unless it came back. What scanner do you have?
Old Oct 10, 2008 | 11:32 AM
xXBadAndyXx's Avatar
true, but at autozone the are not allowed to delete the codes. it will comeback either way though even if you do erase it. i would just find out what codes are being thrown, then work on getting them fixed
Old Oct 10, 2008 | 11:53 AM
fevo's Avatar
turn key 4 times without starting the car , then start ur car ...
Old Oct 10, 2008 | 11:56 AM
DJ Brett B's Avatar
Really? This will clear the code? I have not ever heard of this... are you sure?
Old Oct 10, 2008 | 12:16 PM
jonjon123's Avatar
got it fixed thanks guys
Old Oct 10, 2008 | 12:18 PM
GootBoost's Avatar
what did you do?
Old Oct 10, 2008 | 12:19 PM
that doesnt work
Old Oct 10, 2008 | 12:20 PM
DJ Brett B's Avatar
^ I didnt think it would, it sounded like bs to me!
Old Oct 10, 2008 | 07:31 PM
fevo's Avatar
sure BS ...
I wouldnt care ..
I save 1 trip to dealer yesterday read it from somewhere
hopeful my SES wont comes on again , coz I have battery back up type alarm ,
if i disconnect battery , it will make noise
it works for me only , =P
