Almost to 12's
As of right now I have Buschur turbo back, mbc, S-afc, and a rmr intake on the way. I have been hitting 13.1@106 pretty consistently with 1.8 short times, but my question is what else do I need to hit consistent 12's and :dunno: still keep the driveability the same. What routes would you expert suggest?
Add a little race gas - instant 12's!
Dropping the 60' down a bit would help too. 1.7's are possible, but be careful of the clutch. |
106mph?? that def a 12.9 car
Re: Almost to 12's
Originally posted by Evo2355 I have been hitting 13.1@106 pretty consistently with 1.8 short times, What routes would you expert suggest? Put a little race gas in it and turn the boost up to 20-21psi. I assume you have a boost gauge. That should do it. The other thing I would do is try to shift a little faster. Again with that trap speed you should already be there. |
I am not just looking to hit 12.9's, what other mods would you suggest to hit consistent mid 12's without the help of racegas.
i had a 1.902 60ft. 1/8 8.92@77.59 1/4 14.09@95.14 thats all i could muster outta my stock evo..i need a boost guage cause i feel with my 60ft, time i shoulda hit high 13's do you guys think so???
Wouldn't a dyno tune pull out a few more HP's????
Where are you shift points? Shifting at 6500 RPM showed some strong improvements when I was doing some data logging.
| All times are GMT -7. The time now is 02:22 PM. |
