Almost to 12's
Old Oct 9, 2003 | 04:01 PM
Evo2355's Avatar
Almost to 12's
As of right now I have Buschur turbo back, mbc, S-afc, and a rmr intake on the way. I have been hitting 13.1@106 pretty consistently with 1.8 short times, but my question is what else do I need to hit consistent 12's and still keep the driveability the same. What routes would you expert suggest?
Old Oct 9, 2003 | 04:06 PM
992gnt's Avatar
Add a little race gas - instant 12's!
Dropping the 60' down a bit would help too. 1.7's are possible, but be careful of the clutch.
Old Oct 9, 2003 | 04:11 PM
Rollaway's Avatar
106mph?? that def a 12.9 car
Old Oct 9, 2003 | 04:16 PM
evolutionist's Avatar
Re: Almost to 12's
Originally posted by Evo2355
I have been hitting 13.1@106 pretty consistently with 1.8 short times, What routes would you expert suggest?
First of all I am no expert, but I have run hundreds of 1/4's with my bikes and cars. The first thing I see about your times is , I am a little puzzled. 1.8 60ft and a trap speed of 106mph should put you in the 12.90-99 range. I ran a 13.09 with a 1.811 60ft at 102mph.
Put a little race gas in it and turn the boost up to 20-21psi. I assume you have a boost gauge. That should do it. The other thing I would do is try to shift a little faster. Again with that trap speed you should already be there.
Old Oct 10, 2003 | 05:15 AM
Evo2355's Avatar
I am not just looking to hit 12.9's, what other mods would you suggest to hit consistent mid 12's without the help of racegas.
Old Oct 10, 2003 | 05:24 AM
evo8ya's Avatar
i had a 1.902 60ft. 1/8 8.92@77.59 1/4 14.09@95.14 thats all i could muster outta my stock evo..i need a boost guage cause i feel with my 60ft, time i shoulda hit high 13's do you guys think so???
Old Oct 10, 2003 | 05:44 AM
GroceryGetter's Avatar
Wouldn't a dyno tune pull out a few more HP's????
Old Oct 10, 2003 | 09:17 AM
erioshi's Avatar
Where are you shift points? Shifting at 6500 RPM showed some strong improvements when I was doing some data logging.
ckevoxnyc
Cobb AccessPORT
10
Jun 1, 2016 03:30 PM
BoostEEd
Mar 2, 2007 04:57 AM
zectasy
Oct 23, 2005 08:21 AM
evo8power
Jul 7, 2004 08:15 PM
