can i get a T/S hta 3076?
if Fp don't sell it like that can i just buy a T/S hotside from garret and wack it on?
Yes...The hotside sizes are limited however .. .78ar is about all you can find and will fall off up top.
I don't have any new dyno's on an evo but heres a gt3076r (non HTA) with a .78 divided @ 16psi on a Honda S2000 http://i232.photobucket.com/albums/e...bo/s2kdyno.jpg |
i remember that T/S a/r's are not like single scroll.
i.e a .78 ts is more like a .86 single i think i have that right? so are you allowing for this with your estimate of choking? i also wonder if it will make it surge as the hta is already a modest spooling turbo so with the added t/s could surge? |
Originally Posted by leecavturbo
(Post 7539938)
i.e a .78 ts is more like a .86 single i think i have that right? so are you allowing for this with your estimate of choking? i also wonder if it will make it surge as the hta is already a modest spooling turbo so with the added t/s could surge? i have a t3 1.06 but there super mega rare. hehe. i run t4 now anyways. but to answer your question. yes u can have a ts setup on the 3076. i had one. |
so its the other way!
thx dan {thumbup} |
i wonder why garrett chose not to make more A/r options in that T/S ?
(Post 7539959)
thx dan {thumbup} follow me or did i just make you retarded? HAHA. i sometimes loose my self |
Originally Posted by evodan2004
(Post 7539980)
right. in simple understandable terms. TS housings are so much bigger for a reason. imagine a .63 t3 twin scroll. take a reg t3 .63 and picture it divided. the ports would be much smaller. so they make TS housings bigger. ''.78 .83. 91. 1.00 1.06 1.15 1.32 and so on. a t3 1.06 is ''like'' a t3.82. i be leave the math came out to just shy of .90 but i forget.
(Post 7539963)
(Post 7539999)
right behind ya {thumbup}
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
ATP Turbo sells a 1.06 divided T4 for the 3076R. I've been looking at it for quite some time. Just haven't made the switch. |
You might ask FP whether they can source you the TS housing when you buy the turbo, as then if there is any machining required on the hot side it can be done properly in house before it goes out...
(Post 7539952)
So how can I get my hands on a TS t3 1.06 - have maxed out my T3 .78 not too keen to weld a T4 flange to my manifold as its coated... ? thinking of just switching to single scroll HTA instead. :) |
Originally Posted by jesse@afiturbo.com
(Post 7539925)
I don't have any new dyno's on an evo but heres a gt3076r (non HTA) with a .78 divided @ 16psi on a Honda S2000.
Originally Posted by Ted B
(Post 7542743)
Almost 500whp - impressive. The power is actually still rising at the end of the graph.
Yea i was surprised. I think we can easily do 550whp, however its on e85 and we ran out of injector. |
