can i get a T/S hta 3076?
Old Sep 24, 2009 | 12:41 PM
leecavturbo's Avatar
if Fp don't sell it like that can i just buy a T/S hotside from garret and wack it on?
Old Sep 24, 2009 | 01:01 PM
AFI Turbo's Avatar
Yes...The hotside sizes are limited however .. .78ar is about all you can find and will fall off up top.
I don't have any new dyno's on an evo but heres a gt3076r (non HTA) with a .78 divided @ 16psi on a Honda S2000
Old Sep 24, 2009 | 01:05 PM
i remember that T/S a/r's are not like single scroll.
i.e a .78 ts is more like a .86 single
i think i have that right?
so are you allowing for this with your estimate of choking?
i also wonder if it will make it surge as the hta is already a modest spooling turbo so with the added t/s could surge?
Old Sep 24, 2009 | 01:09 PM
EvoDan2004's Avatar
a .78 is more like a .63 single.
i have a t3 1.06 but there super mega rare. hehe. i run t4 now anyways.
but to answer your question. yes u can have a ts setup on the 3076. i had one.
Old Sep 24, 2009 | 01:11 PM
so its the other way!
thx dan
Old Sep 24, 2009 | 01:13 PM
i wonder why garrett chose not to make more A/r options in that T/S ?
Old Sep 24, 2009 | 01:16 PM
EvoDan2004's Avatar
thx dan
right. in simple understandable terms. TS housings are so much bigger for a reason. imagine a .63 t3 twin scroll. take a reg t3 .63 and picture it divided. the ports would be much smaller. so they make TS housings bigger. ''.78 .83. 91. 1.00 1.06 1.15 1.32 and so on. a t3 1.06 is ''like'' a t3.82. i be leave the math came out to just shy of .90 but i forget.
follow me or did i just make you retarded? HAHA. i sometimes loose my self
Old Sep 24, 2009 | 01:19 PM
right behind ya
Old Sep 24, 2009 | 01:20 PM
EvoDan2004's Avatar
they make a few. but none that we like to use for smaller type turbos.
Old Sep 24, 2009 | 01:21 PM
EvoDan2004's Avatar
right behind ya
they make a t4 1.06 for the 30r but there also very hard to find. but if i had to do a ts30r all over again i would do nothing less then a 1.06. but good luck finding one.
Old Sep 24, 2009 | 01:26 PM
redleg225's Avatar
http://www.atpturbo.com/mm5/merchant...egory_Code=GRT
ATP Turbo sells a 1.06 divided T4 for the 3076R. I've been looking at it for quite some time. Just haven't made the switch.
Old Sep 24, 2009 | 01:27 PM
CO_VR4's Avatar
You might ask FP whether they can source you the TS housing when you buy the turbo, as then if there is any machining required on the hot side it can be done properly in house before it goes out...
Old Sep 25, 2009 | 03:55 AM
supersal's Avatar
So how can I get my hands on a TS t3 1.06 - have maxed out my T3 .78 not too keen to weld a T4 flange to my manifold as its coated...
thinking of just switching to single scroll HTA instead.
Old Sep 25, 2009 | 07:17 AM
Ted B's Avatar
Originally Posted by jesse@afiturbo.com
I don't have any new dyno's on an evo but heres a gt3076r (non HTA) with a .78 divided @ 16psi on a Honda S2000.
Almost 500whp - impressive. The power is actually still rising at the end of the graph.
Old Sep 25, 2009 | 04:16 PM
AFI Turbo's Avatar
Yea i was surprised. I think we can easily do 550whp, however its on e85 and we ran out of injector.
