POLL: FP Red or BBK
***NOV 2011 UPDATE: Back from Afghanistan! Went with BBK Full. Results in link below.
https://www.evolutionm.net/forums/ev...octane.html*** You read the title. Going to do turbo upgrade this spring and not sure if I want FP Red or BBK. Heard great things about both, and just trying to get everyone's opinions on everything. I know this has been covered probably before but a poll hasn't been done (I searched). Along with the FP Red/BBK turbo, I'm going to do FP 18 or 25psi wastegate, Shearer O2 dump, Shearer manifold, Forge RS BOV and 780-880cc injectors. Anything else you think I need let me know, and I will look into it. Goals are 400whp, 400wtq on Mustang Dyno or 450+whp and 425+wtq on Dynojet. I will not use meth, E85, c16, etc. I will only be using straight 93 octane pump gas. Thanks all. Current Mods are: Greddy Full Titanium Exhaust DC Sports Downpipe/Test Pipe Greddy 264/264 Cams AMS FMIC ACT HD-TTP 6-Puck Clutch Kit XACT Streetlite Flywheel Injen Upper/Lower Intercooler Piping Injen Intake TTP/Megan O2 Housing Walbro 255lhp Fuel Pump ARP Head Studs Hallman PRO RX MBC 26psi taper to 20.5(ish) stock ix turbo stock injectors stock exhaust/intake manifold no porting 364whp/358wtq on TTP's Mustang Dyno Future Mods with Upgraded Turbo will be: Shearer/Full Race Exhaust Manifold Shearer O2 Dump 880cc + injectors Forge RS BOV If I do FP Red, I'll use 25psi wastegate, if I do BBK it will be their wastegate (obviously) 30NOV2009 - EDIT: Original goals were "450whp, 430wtq on Mustang Dyno and 480+whp and 450+wtq on Dynojet" but after some more research, on 93 octane, this is probably unrealistic. 29DEC2009 - EDIT: So I'm getting deployed in September 2010 so a turbo upgrade MAY be out of the question until I get back. Don't really want to do the upgrade and have the car sit for all that time only a few months after it does in. That said, I'm going to wait and see what's out from CBRD and FP in the spring/summer before I go I may buy it and have it sit in the box for when I get back :D. This thread however, is a very good source of information for BOTH turbos and shoudn't be deleted. Thanks! {thumbup} NOV 2011 UPDATE: Back from Afghanistan! Went with BBK Full. Results in link below. https://www.evolutionm.net/forums/ev...93-octane.html |
BBK with the standard WGA (wastegate actuator). Great, reliable, turbo capable of holding plenty of boost with the stock WGA. Get a nice porting/coating job on the turbine housing and look into a ported intake manifold and throttle body.
You can also look into the FP HTA Green which is FP's answer to the BBK and what they're calling the ultimate pump gas turbo (like CBRD claims about the BBK). |
Price wise, the HTA Green is as much as the Red almost....so why not get the Red? And for the stock WGA, you think the one with the BBK will hold 23-25psi at redline?
I'm not sure your going to make your power goals with those cams they are too mild. You need big boy cams to make the power you seek. Also I'm not a BBK expert but if you look at my sig you will see how much power I made with the Red on 93 it actually made more but we also had 5 counts of knock at 480hp so 469 was perfect
I would go for the red. I like the quicker spool up and for you goal the red would hold out. Be careful with the stock internals. I would also look into 272 - 280 cams.
Originally Posted by EvoRob22
(Post 7737680)
is it just me or does ttp mustang dyno seem to read a bit high for the mods listed? have seen other cars they have done and thought similar..
Its going to be tough to get 450 on a real dyno on pump with either turbo ;). Stop worrying about numbers.
(Post 7737680)
Originally Posted by Cali2MDevo8
(Post 7737742)
Wait until that BBK Beta comes out it looks like a competitor!
Originally Posted by EriCS
(Post 7737751)
+1 on watching those stock internals. I read you should steer away from going past 425 wtq on stock internals. I feel your undecisiveness on which turbo to get. I have spoke with other tuners on the board and most seem to feel that the RED is a good option due to the fact there is always room to step up the game if you get needy for more power. These turbos seem to make the same power psi for psi but the Red out shines the BBK over 28 psi. BBk has earlier spool and good transient response. I also like the fact there are minimal turbo failures on these turbos but I don't think there pushed as hard as the REDS. All in all there both good and I don't think you can go wrong with either. If your weiry on a slightly slower spool get the BBK otherwise the RED.:D
Originally Posted by DBallz
(Post 7737816)
Oh boy here you go my #1 worry wart. If you your tuner knows what they are doing then your internals will be fine. 469 no problems with my car.
Originally Posted by mitsuevo803
(Post 7737571)
As for the HTA Green vs. the Red it all depends what you want more of, low-end response or top-end pull? Both are good turbos but are aimed at different things. I just figured since you're looking at the BBK the HTA Green would also be worthy of a look since they're the direct competitors. You really can't go wrong with the BBK though, its proven to be just as durable as the stock turbos with torque coming on sooner than with the Red. |
(Post 7737816)
p.s. If you look at your tune your not really close to the threshold so your "tune" is isn't aggressive enough to be concerned. Hp number don't mean much... |
