IAC Valve question
I have a spare IAC that I took off my car due to idling issues (the IAC wasn't the problem). Does anyone have a diagram for the IAC plug so I can test it? I want to make sure it's a good IAC valve before I sell it. I guess I just need to know what pins I need to hook a power and a ground to.
Thanks |
Ttmft
No one knows?
I was told if you disconnect it from the TB and leave the wires/harness on it and put the key to the on position (maybe crank it over??) you should hear/see the shaft move/turn if it is still good.
Give that a shot... **confirm this before attempting...** |
Thank you. I was leaning more towards just somehow giving it power via 12v battery. The valve has 6 pins but as far as I know it should only need power and a ground to actuate.
I'm aware of the suggestion you mentioned though. Thanks for the input. |
More help please.
Thank you Evoryder, I'll try this out tomorrow tomorrow when there's more light and after my hangover wears off.
Thanks again. |
^ Any luck?
yes, any luck? i think my IAC is bad ('03 Evo8) and may need to replace mine.
^ test it first...
I bought a new one but it didn't solve my idle stumble problem. Wasted $300- |
