Figuring out cfm flow numbers for our 4g63's
How do you figure out the cfm flow numbers for our Evo engine?
I know how to figure out the flow for a na engine. But I am not sure how to compensate for the turbo and the additional flow it creates. Anyone know? SC~ |
The December issue of Hot Rod magazine has an article about turbos and part of it touches on your question. I couldn't find it on their web site but it is definitely in the Dec. mag. The major variable is volumetric efficiency. At 100% cfm is a pure calculation based on displacement and rpm. They say assume at least 100% for a turbo motor. They are measuring air flow in pounds per minute, not cfm and have conversion factors, etc. Really good article and this is only part 1 of 3.
the air flow formula is
CDI * rpm * VE * .5 -------------------------- .... ....1728 to arrive at CDI take CC and divide by 16.4 VE is usually in the .9 (90%) range that will give you naturally aspirated airflow in CFM to arrive at a boosted CFM multiply the NA air flow number by the pressure patio (PR) PR= 14.5 + boost pressure (in psi) ----------------------------------------- .... .... ...14.5 so a boost pressure of 14.5psi or one bar would have a pressure ratio of 2 have fun plugging away aaron edit: if you are trying to plot compressor maps you might need to convert your final number into lb/min. to do so multiply by .0691 |
Thats some good info Dale/ Aaron. Thanks.
I'm going through this exercise to figure out what kind of intercooler is needed for our engines. I found a site that custom builds intercoolers...but they list the applications by air flow needs. Plus I am building a Turbo Austin Mini at home right now. And I'll need to eventually get an intercooler for the 1.3L engine. And it has to be a custom built one due to the size constraints of the engine compartment..... SC~ |
dont know if it is relevant but when i have done datalogging with my scanner, at full WOT i have seen around 29 t0 31 lb/min of air flow
Originally posted by SuperchargedGTZ dont know if it is relevant but when i have done datalogging with my scanner, at full WOT i have seen around 29 t0 31 lb/min of air flow just for chits and giggles... What was your boost pressure and rpm at that reading. we might be able to calculate a true VE number for this engine. edit: I will also need your elevation above sea level. |
| All times are GMT -7. The time now is 07:45 PM. |
