-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   mods I'm thinking about making (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/50191-mods-im-thinking-about-making.html)
Moki97 Nov 17, 2003 10:23 PM
Here are some mods that I'm thinking about making. What do you all think?
- Tanabe Ultra medalion Exhaust
- Tanabe Down pipe
- HKS Racing Suction intake system
- HKS 264 Camshafts
- HKS cam gears
- FIC 750 injectors
- HKS circle earth system
- Re-mapped ECU
- Exedy hyper twin plate clutch kit
- JIC FLTA2 coilovers
- Cusco 25mm front sway bar
- Cusco 23mm rear sway bar
- Cusco titanium front sway bar tower bar
- Cusco rear strut tower bar
Coolguy949 Nov 17, 2003 10:27 PM
the injectors will be overkill for the stock turbo, or even anything smaller than a 3037.
MP5 Nov 17, 2003 10:28 PM
Re: mods I'm thinking about making
- Tanabe Down pipe
- HKS 264 Camshafts
- HKS cam gears
- FIC 750 injectors
- Re-mapped ECU
Sorry but WTF do you need 750 injectors?
IS2000 Nov 17, 2003 10:30 PM
Yep, I think stock injectors should be fine for the mods that you'll be running.
Moki97 Nov 17, 2003 10:32 PM
Thanks for your help. Any other suggestions for mods...
Coolguy949 Nov 17, 2003 10:35 PM
If you want some more fuel, go with a 255lph pump.
FYI, Exedy twin plate is out of stock (backorder) until the end of the year. But i'm sure you wont put it in that soon anyway.
chrismr Nov 17, 2003 10:44 PM
i have the hks gd max twin plate clutch.. love it.. another clutch option..
4G63>OOOO Nov 18, 2003 05:58 PM
Hey, stop spamming all the clutch threads. It's annoying.
ex-honda Nov 18, 2003 09:39 PM
Man. With all those mods, you must be rich! LOL
954DRGSR Nov 19, 2003 07:06 AM
- Tanabe Down pipe
- HKS 264 Camshafts
- HKS cam gears
- FIC 750 injectors
- Re-mapped ECU
Looks good - for what its worth here are my suggestions:
1. Forgo the intake until bigger turbo. See some comments on this by Shiv here (look at Shiv' scomments towards the end of teh page)https://www.evolutionm.net/forums/sh...threadid=50224
2. As stated by Coolguy949, you don't need the larger injectors until bigger turbo.
3. You might want to forego the front swaybar although this depends on your driving style. For an alternative swaybar choice and some good info see: http://www.roadraceengineering.com/evoswaybar.htm . I added a larger front and rear one to my Integra and ended up changing the front one back to stock - car wouldn't rotate right.
BPAuto Nov 19, 2003 07:26 AM
- Tanabe Down pipe
- HKS 264 Camshafts
- HKS cam gears
- FIC 750 injectors
- Re-mapped ECU
Looks like a good list. I assume you already have SAFC and a boost controller as well? You also may want to consider an HKS or ATS twin-plate clutch.
Moki97 Nov 19, 2003 08:18 PM
[QUOTE]Originally posted by Moki97
[B]Here are some mods that I'm thinking about making. What do you all think?
- Tanabe Down pipe
- HKS 264 Camshafts
- HKS cam gears
- Re-mapped ECU
How much horsepower did you think I would be putting out with these mods?
Zeus Nov 19, 2003 09:01 PM
I think Buschur went with larger injectors on the stock turbo for a reason... just not that large. Fuel pump is a must, a step up in injectors would be nice... but what do I know?
djp0is0n Nov 19, 2003 09:20 PM
honestly i think the Tomei poncam n ecu response is better.... n why not try the RSR mufflers? killer noize!!! my opinion only.. :D
evoLuzN Jul 26, 2007 08:41 PM
with those performance settings, i believe you will get like 330whp but lots of good stuffs at suspension, have fun with em~
PS: with all those good stuffs for suspension, why not throw your money in engine parts? Stock suspensions are more than enough. (OEM suspension can held up to 400whp, dont worry about em)
