Evo VIII stock, should I imitate turbo timer?
My car is stock except the turbo back exhaust, so I was wondering if I should warm up the engine before driving and if I should leave the engine running for some time after a ride, like the turbo timer does?
doesnt hurt
Warm up the engine - absolutely.
Letting the car cool down a little - Yes. I used to live on a Military installation, so after getting off the freeway and driving around on base, that was my cool down period as the speed limit was only 25 MPH. I would sit in the car ~30 seconds for safety's sake. |
def wouldn't hurt to warm it up at start and to let it idle for a bit before turning off
If you've been driving it hard and on boost then drive it at about 3000 RPM for a mile or two before pulling into your garage. I think that driving off boost at relatively low RPM's is better than letting the engine idle for extended periods of time as a turbo timer would. Extended engine idle periods produces unburned contaminants in the engine oil.
As far as warming it up is concerned, I just fire it up in the morning and drive off wile keeping engine revs under 2000 RPM until the engine oil has a chance to reach operating temperature. An oil temp gauge is a useful device. |
def warm up the engine lol If ur hitting full boost I would also let it sit for a bit.
I have the greddy full auto turbo timer. Love it! |
Well for me my car runs like straight **** when its cold, so i just let it sit for a few minutes until the temperature hits C then i start driving, and no passing 3k rpm before the oil is at the correct temp.
As for shutting off you could wait like 30 seconds or a minute if you want to if you've been driving it really hard, i don't think its that big of a deal with just boost here and there. Or if you've already been driving for like 5 minutes normally after driving it hard then it doesn't even really matter. |
I thought you weren't really supposed to let your car idle up to temp. I don't think the manual addresses this, but I know on my last car the manual said keep it under 3k until it got to operating temp, it was a turbocharged 4 cyl engine. I just keep it under 3k. It only takes a minute or two to warm up any way.
If I have been off boost within around 3 minutes of my destination, I just let it idle for a few seconds before I turn it off.
If I have been on boost within a few minutes of my destination, I will let it idle till the fans kick on. I will then wait for the fans to turn off before I shut off the engine. If I have been romping the sht out of it, then I will let it go through a few fan cycles. :) |
Originally Posted by Evo-B
(Post 8525746)
Originally Posted by FJF
(Post 8526045)
I hope you're not gauging this by the water temp. Oil temp usually takes a bit longer to come up.
