APR head and main studs specs? help
Does anyone know the torque specs for APR main and head studs? I
Pretty sure these are them:
Head studs - 80ft lbs Main studs - 60 ft lbs Rod bolts - 40 ft lbs |
thats with the Moly Lube, I'm not sure off hand what it would be with motor oil
i did my rod bolts to 60ft/lbs with moly, 60ft/lbs for the mains too.
Make sure you check the mains tunnel bore for roundness after installing main studs, you might need to line hone it. |
