APR head and main studs specs? help
Old Oct 18, 2010 | 06:56 PM
usacchamp's Avatar
Does anyone know the torque specs for APR main and head studs? I
Old Oct 18, 2010 | 07:17 PM
b16a95eg's Avatar
Pretty sure these are them:
Head studs - 80ft lbs
Main studs - 60 ft lbs
Rod bolts - 40 ft lbs
b16a95eg's Avatar
thats with the Moly Lube, I'm not sure off hand what it would be with motor oil
Old Oct 19, 2010 | 01:30 AM
RSMike's Avatar
i did my rod bolts to 60ft/lbs with moly, 60ft/lbs for the mains too.
Make sure you check the mains tunnel bore for roundness after installing main studs, you might need to line hone it.
Dream Came True
15
Jul 10, 2012 01:04 AM
48T080
Feb 22, 2009 08:24 PM
Wayne99gsr
14
Jul 11, 2008 02:24 AM
EVO Tweeker
Northwest Region
24
Apr 9, 2008 12:16 PM
cneio
10
Mar 31, 2006 02:39 PM
