Should I upgrade APR head studs?
Old Jul 3, 2008 | 10:55 PM
Wayne99gsr's Avatar
Got a set of HKS 272s and going to install it this weekend. should I order the studs as well and then install them at the same times?
Old Jul 3, 2008 | 11:11 PM
whytrySTi?'s Avatar
this is kinda a 50/50 opinion. Some will say do it some will say no need. Depends on boost level. So i'll leave it at that since im kind of clueless on this topic also. We'll see what the majority says.
Old Jul 3, 2008 | 11:22 PM
EvoJoeIX's Avatar
just do it while your in there
Old Jul 3, 2008 | 11:24 PM
sspaladin28's Avatar
Why not since the install is free while they are in there anyway. Its almost pointless not to for the cost of the studs
Old Jul 3, 2008 | 11:39 PM
mitsuevo803's Avatar
as it was explained to me-its a one hundred dollar insurance for your car...same with the walbro when running more boost
Old Jul 3, 2008 | 11:43 PM
SME's Avatar
SME
If your running around stock boost you will be fine but why not change them while your in there. That way if you ever want to race boost for the track or something you wont need to worry!
Old Jul 4, 2008 | 06:54 AM
justboosted02's Avatar
dont do it, there is no need
if you need to change them then you should replace the head gasket at the same time. if you dont you run the risk of developing an oil leak at the back of the block which happens quite frequently
Old Jul 10, 2008 | 05:37 PM
wartownracer's Avatar
so if i upgrade my headstuds and head gasket at the same time everything will be cool?
Old Jul 10, 2008 | 05:44 PM
htsai14752's Avatar
what's the max boost to not go over for stock headstuds?
Old Jul 10, 2008 | 08:32 PM
EvoJoeIX's Avatar
i believe like 28 psi
there are people that run more boost then that on stock bolts, but its only time before disaster will strike. better to be safe then rebuilding a motor...
Old Jul 10, 2008 | 08:47 PM
hanahawaiian's Avatar
dont do it.., it dont need..
my evo run 24psi with M3 cams.. and never iuess.. it method of DSM tuner do apr head studs... but evo dont need... as long u upgrade to bigger turbo
Old Jul 10, 2008 | 10:04 PM
KevinD's Avatar
i've been at 30psi on my 35r for over 10k miles with stock head studs
don't change them. there is no need to. i've seen a couple leaky headgaskets from the 1by1 method, but i've never seen a stock stud fail from running to much boost.
Old Jul 10, 2008 | 10:18 PM
tsi20gawd's Avatar
Ive been running between 28-30psi on a ix turbo on pump daily for a few months now no issues to speak of, then again I have a few mods to make this easier that you might not have yet. Its more important to keep a watchfull eye on knock than a specific boost number imho.
Bryan
Old Jul 10, 2008 | 10:20 PM
Billy@EnglishRacing's Avatar
no you will be fine
Old Jul 11, 2008 | 02:24 AM
1NastyMR's Avatar
Might as well its only like 110$... they will just provide more reasurance
Sly Moose
11
May 27, 2011 06:33 AM
kmcconn9
Oct 8, 2009 06:38 AM
EvoJoeIX
May 25, 2008 07:18 AM
tkklemann
Apr 5, 2006 09:13 AM
patan
May 25, 2004 03:43 PM
