stud and bolt spinning....
Old May 23, 2008 | 08:35 PM
EvoJoeIX's Avatar
the bolt that goes from the manifold into the turbo. i go to take it off and i notice that the stud is spinning with it. the bolt is not stripped, the stud is loosening up as im loosening the bolt, i just stopped and tightened it back down because i do not want to break my stud
so my question is, how can i keep the stud from spinning? i need to get this bolt off to put my manifold on. i was thinking heat the bolt, since that would expand the bolt and should loosen it off the stud. anyone have any other ideas?
Old May 23, 2008 | 09:30 PM
Ivan@AMS's Avatar
It will probably just come off like a bolt.. Remove it and replace it like a bolt.
Old May 23, 2008 | 09:32 PM
EvoJoeIX's Avatar
no i have had it off before, the stud is not supposed to come off with the bolt. only the bolt should come off
Old May 23, 2008 | 09:37 PM
Ivan@AMS's Avatar
I understand what you are saying....... but a stud is threaded on BOTH ends. If the nut sticks to the stud but the stud is un-threading from the turbo... pull it out just like a bolt
Old May 23, 2008 | 09:39 PM
EvoJoeIX's Avatar
see i would, but its very tight and i dont want to snap the stud cause then im screwed. i understand what you are saying, but the stud isnt easy to loosen
Old May 23, 2008 | 09:42 PM
Ivan@AMS's Avatar
Gotcha... from your first post, it sounded like you implied it was un-threading fine.
PB Blaster and some heat... Use anti seize when you put those back on.
Old May 23, 2008 | 09:44 PM
EvoJoeIX's Avatar
sorry about that man,
but yea i feel like i might snap it, so ill try some heat on it tomorrow
i hear you on that anti-seize, when i had all my manifold bolts off tonight, i made sure to use anti-seize putting them back on, so i dont run into this problem when i work on it tomorrow.
thanks for the help
Old May 24, 2008 | 07:58 AM
Tallen's Avatar
Silver Sponsor
Chances are that the stud, as stated, is backing out. Not an uncommon event. Take it all out, put vice grips on the bare part of the stud (be careful, use a rag) or put it in a vise, then take the nut off. After that, put it back in handtight or use a stud installer, then put it back in.
If you are takin the manifold off, you can lock two nuts onto the outside of the stud and install it that way. You tighten the nuts against each other, then use a wrench to put it on, don't tighten the stud too much...use the green super permanent loctite on it.
Listen to EVO Joe and use antisieze. When it comes to high temp stuff, use copper.
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
Old May 24, 2008 | 08:08 AM
EvoJoeIX's Avatar
guys the stud is not spinning freely and feels like it could snap if i keep trying to take it out. thats why i stopped. im not gonna take a chance of snapping it off inside the turbo hotside
Old May 24, 2008 | 09:56 AM
cfdfireman1's Avatar
PB-Blaster and let it soak
Old May 24, 2008 | 12:54 PM
Tallen's Avatar
Silver Sponsor
Try the PB as stated above. If you are afraid the nut is locked on the stud, buy a nut splitter and remove the nut so the stud isn't damaged!
Oh and forget my comment on the green loctite, I was thinking you were working on the intake manifold.
As a side not, studs normally do not come out easy, they give resistance all the way. It likely would not loosen up instantly and be finger tight like a bolt is.
__________________
-Matt
Old May 24, 2008 | 09:33 PM
EvoJoeIX's Avatar
nut splitter?
never heard of that, where can i find one at
Old May 25, 2008 | 04:14 AM
Tallen's Avatar
Silver Sponsor
Auto zone, etc store. They are cheap in the tool section. It is a handy tool to keep around, just make sure to get yourself another nut! Maybe someone will chime in and verify M10x1.25 as the proper size.
It will look similar to this.
http://www.northerntool.com/webapp/w...70_34573_34573
__________________
-Matt
Old May 25, 2008 | 07:18 AM
EvoJoeIX's Avatar
oh okay, i see how it works.
i will try that if it doesnt come loose today, i let it soak all night in pb blaster.
so if its not loose after today, i will go get that tool and split that mother!
AustinB768
15
Jul 18, 2012 07:44 AM
Evokid8
Jul 7, 2009 05:59 PM
stevEVO8
21
Feb 13, 2008 01:04 PM
evoXIII
Jun 3, 2007 06:56 AM
vtluu
Jul 24, 2005 08:33 PM
