how to install head stud
Old May 25, 2004 | 03:24 PM
patan's Avatar
where i can find the web page of the torque of each arp head stud, instalation of evo.?
Old May 25, 2004 | 03:29 PM
93h22cvc's Avatar
usually torque the head studs 75ft-lbs all 10 of them.then go back and bring them all up to 85ft-lbs
Old May 25, 2004 | 03:39 PM
Quickshift's Avatar
Work your way from the middle ,torque your nuts to 75ft with the moly lube supplied with the headstuds. Hand tighten the studs into the block, and if you want give it a couple turns with allen wrench but dont make very tight.
This is the order of stud install.
Intake side
8 6 1 3 9
10 4 2 5 7
Exhaust Side
Each of those numbers represent a headstud on the head. Just remove and replace one stud at a time, in that number sequence.
Hope that helps some, use evomoto.com and look at there cam install to get an idea of all the torque specs for all the other items attached to the valve cover.
Old May 25, 2004 | 03:43 PM
patan's Avatar
thanks,i get already the idea
Sheasta
Oct 29, 2015 05:00 PM
EVO 4 life
Oct 26, 2015 08:11 PM
maperformance
Jul 26, 2010 03:35 PM
riceball777
43
Oct 12, 2008 08:26 PM
Wayne99gsr
14
Jul 11, 2008 02:24 AM
