Opinions on good replacement clutches (~400whp)
what clutch should i get if i am making around 400hp?
Opinions on good replacement clutches.
Hi!
I'm going to be replacing my clutch and am looking for input on new clutches. In general I'm pretty easy on hardware, I got 133,000 out of my stock STI clutch. This is my first Evo clutch change. Supposedly the previous owner installed an Exedy stage 2 and that's what I've been driving for the last 25,000 miles. I'll verify what it actually is when it's replaced. (Update 2-18-2011 it is an Exedy Stage 2 Clutch!) It has a pretty heavy pedal to disengage the clutch and is noisy (clattering noise) when you're doing things like backing up or taking off at a stop light and trying to be gentle with it. The heavy pedal, I've gotten used to, but the clattering, I haven't. But that being said if it is an Exedy stage 2, what is the normal life expectancy of this clutch? And now the real question which clutch next? I might eventually build it to around 400 HP at the wheels, but for now and probably the next 8 months it remains stock. I'm looking for day to day usability but with some room for mods. I can handle a heavy pedal, but I don't like the noise It might get taken to the track every once in a while for some laps but not drag racing. Can I get a daily usable street clutch for around 400 HP 400 TQ at the wheels or at this point am I being unreasonable? Feel free to tell me if I'm being unreasonable or to get all of that it costs $$$ or you can expect to get a clutch that will hold 350 HP/350 TQ without being chattery. I'm sorry if this is a stupid question, but I just don't have any reference on what to expect. Here's what I'm considering.. OEM replacement clutch Exedy MBK1001, probably not but maybe. Exedy Stage 1 05803 Maybe Exedy Stage 1 05803HD Maybe Exedy Stage 2 05952 If it's actually what I have now probably not. or maybe a ACT street clutch model. (I know that there are several). Anything else I should consider??? Any ideas or opinions would be appreciated. Thanks |
Im going with a ACT XTSS to replace my stock clutch. Heard its a little stiffer from stock but nothing big.
I ran a ACT HDSS (street disc) clutch for 50k miles. I was putting down 360 tq and had about 25 launches on it. When I took it out it still looked fine. Daily driving was very easy with this clutch.
Get Act HD SS or Act 6 Puck
Look into the WORKS CK2 clutch too.
I drove an Exedy Stage 2 HD and it was too much for me to consider livable in a daily-driver. |
ACT HDSS I have used personally with great results. Do a search, theres tons of threads on this already.
Exedy twin disk a lot of people use too. When i get in the market for a new clutch the exedy is the one i'm going with...
ACT HDSS all day
I have an Act xtss. Holds 508 ft/lbs. Very easy to live with. At first i was reluctant to go act because of all the bad rumors about them, but then I thought, wth might as well take a leap of faith. Turns out this clutch is great! Act hdss and xtss are great clutches, just take them to a good installer.
I am in your same situation. I plan to go with FP HTA Green and 400/400 max.
I talked to a couple of vendors/transmission shops on what they suggest I go with. I wanted something very liveable on the street, with a long life-span, but be able to handle the power. I don't drag race, and am not a big fan of launching on original t-case/trans. The clutch two of the vendors agreed upon was the Clutch Masters FX300. It has a kevlar friction surface, which takes longer to break in, but will last longer and has a smoother/quieter engagement. Each clutch is tested before it leaves the factory. The FX300 is rated to 550ft-lbs @ the flywheel. Haven't had a chance to install is yet, but here are some pictures: http://i137.photobucket.com/albums/q...9/IMG_1247.jpg http://i137.photobucket.com/albums/q...9/IMG_1246.jpg |
HDSS hands down if you don't plan on shifting past 7800 rpm daily.
I can't wait to replace that SOB but it won't die. 70k miles on it and it still performs great til 7800 |
thanks for the info, i got lots of options it looks like
act hd ,works rilly good on mine...
