Upgrading from my HKS 272's
So earlier I took off my valve cover and found a broken rocker arm which then made the cam lobe smack the lifter and bending the top of the valve and scratching up the lobe a little in the process, I don't see it why it wouldn't be saveable but with all the nonsense I hear how these are crap cams and the need to have more power I want to upgrade to something better. I'm searching but isn't helping much, what should I be looking to get? Must be RELIABLE.
Engine specs are in my thread, currently around 25-30psi but will prob be going up to mid 30's or whatever Ivey decides to do with it. Driveability comes before power, I know it depends on the tuner but I don't want something with alot of overlap so it barely idles and have crap mpg since I drove over 100 miles a day. Thanks |
My vote would be HKS 280's. They're great cams for the VIII.
kelford 272 make strong power on evo 8 or gsc
GSC S2s or Kelford 272s.
Yes the Kelford 272 's with the GSC no tick lifters.
These cams made 40whp more over the HKS 272's, with a similar setup up. |
make sure you get the NEW gsc s2 and not old.. the new ones are bigger then kelford 272
gsc1
Originally Posted by tscompusa
(Post 9076657)
for a daily, I'd get GSC S1. tons of torque w/ wide power band. 350/350 w/ 9 stock turbo on dynojet. smooth as stock. prob most enjoyable cams on street, for me that is.
I had those exact HKS cams and were less than impressive but lopey as hell. Also, had comp 280, great cams for high rpm power for drag strip. it was a blast. |
Sweet Thanks!
so can you tune gsc s2 idle as smooth as stock?
+1 for gsc s2's
Originally Posted by a4rontran
(Post 9078000)
That's what I'm hoping, I don't want to have a lopey idle, then again mine sounded like it had stock cams in it compared to others ive heard on youtube with the same cams I have, prob because my idle was around 1200. Ivey will be tuning it so I know I'll be in good hands anyway.
I'm looking at the GSC S2 and so far Boston Motorsports has had the BEST DEAL on the cams and lifters I need |
| All times are GMT -7. The time now is 10:32 PM. |
