Upgrading from my HKS 272's
Old Feb 14, 2011 | 08:05 PM
My03evo's Avatar
Arrow Upgrading from my HKS 272's
So earlier I took off my valve cover and found a broken rocker arm which then made the cam lobe smack the lifter and bending the top of the valve and scratching up the lobe a little in the process, I don't see it why it wouldn't be saveable but with all the nonsense I hear how these are crap cams and the need to have more power I want to upgrade to something better. I'm searching but isn't helping much, what should I be looking to get? Must be RELIABLE.
Engine specs are in my thread, currently around 25-30psi but will prob be going up to mid 30's or whatever Ivey decides to do with it. Driveability comes before power, I know it depends on the tuner but I don't want something with alot of overlap so it barely idles and have crap mpg since I drove over 100 miles a day.
Thanks
Old Feb 14, 2011 | 08:19 PM
recompile's Avatar
My vote would be HKS 280's. They're great cams for the VIII.
Old Feb 14, 2011 | 08:37 PM
tscompusa2's Avatar
kelford 272 make strong power on evo 8 or gsc
Old Feb 14, 2011 | 08:41 PM
FastLearner's Avatar
GSC S2s or Kelford 272s.
Old Feb 14, 2011 | 08:43 PM
evo8tp's Avatar
Yes the Kelford 272 's with the GSC no tick lifters.
These cams made 40whp more over the HKS 272's, with a similar setup up.
Old Feb 14, 2011 | 08:45 PM
tscompusa2's Avatar
make sure you get the NEW gsc s2 and not old.. the new ones are bigger then kelford 272
Old Feb 14, 2011 | 08:58 PM
xRoguex's Avatar
gsc1
Old Feb 14, 2011 | 09:17 PM
ecktt's Avatar
How can you tell? Would this be the new S2?
Old Feb 14, 2011 | 10:06 PM
spyderx's Avatar
for a daily, I'd get GSC S1. tons of torque w/ wide power band. 350/350 w/ 9 stock turbo on dynojet. smooth as stock. prob most enjoyable cams on street, for me that is.
I had those exact HKS cams and were less than impressive but lopey as hell.
Also, had comp 280, great cams for high rpm power for drag strip. it was a blast.
Old Feb 14, 2011 | 10:28 PM
tscompusa2's Avatar
look at the SKU #
http://www.power-division.com/produc...cat=279&page=1
Old Feb 15, 2011 | 06:33 AM
ecktt's Avatar
Sweet Thanks!
Old Feb 15, 2011 | 10:30 AM
a4rontran's Avatar
so can you tune gsc s2 idle as smooth as stock?
Old Feb 15, 2011 | 12:54 PM
e.v.o IX's Avatar
+1 for gsc s2's
Old Feb 15, 2011 | 08:21 PM
grim~'s Avatar
you can tune most cams to not be lopey
Old Feb 16, 2011 | 01:01 AM
My03evo's Avatar
That's what I'm hoping, I don't want to have a lopey idle, then again mine sounded like it had stock cams in it compared to others ive heard on youtube with the same cams I have, prob because my idle was around 1200. Ivey will be tuning it so I know I'll be in good hands anyway.
I'm looking at the GSC S2 and so far Boston Motorsports has had the BEST DEAL on the cams and lifters I need
