Kelford 280 vs BF272?
This is on a 2.0 revving to 9.5k on a 67mm turbo. Anyone have some data?
I say BF 272 over a kelford.... but have you looked into s3s or tomei 280s or big cams like that?
Take it for what it is, comp280s vs buschur bf272s, same boost both cams set strait up. Buschur cams in red comp280s in the blue. Buschur cams where tested when it was about 20degrees cooler in the dyno room. http://i91.photobucket.com/albums/k3...6/oldvsnew.jpg
BF272 has higher lift than kelford 272?
Kelfords any day! But yes check the gsc s3s there great cams as well
The S3's would make more power for sure, but I would go with the kelford 280's over the BF272's for the larger duration which will be helpful in the higher rpm's.
Originally Posted by mxguy1286
(Post 9172179)
