Kelford 280 vs BF272?
Old Mar 18, 2011 | 11:23 PM
omniprobe's Avatar
This is on a 2.0 revving to 9.5k on a 67mm turbo. Anyone have some data?
Old Mar 19, 2011 | 03:19 PM
1NastyMR's Avatar
I say BF 272 over a kelford.... but have you looked into s3s or tomei 280s or big cams like that?
Old Mar 20, 2011 | 07:02 AM
mxguy1286's Avatar
Take it for what it is, comp280s vs buschur bf272s, same boost both cams set strait up. Buschur cams in red comp280s in the blue. Buschur cams where tested when it was about 20degrees cooler in the dyno room. http://i91.photobucket.com/albums/k3...6/oldvsnew.jpg
Old Jul 29, 2011 | 12:12 PM
doghouse's Avatar
BF272 has higher lift than kelford 272?
Old Jul 31, 2011 | 05:33 PM
Derock2gspyder's Avatar
Kelfords any day! But yes check the gsc s3s there great cams as well
Old Jul 31, 2011 | 05:42 PM
BenJ's Avatar
The S3's would make more power for sure, but I would go with the kelford 280's over the BF272's for the larger duration which will be helpful in the higher rpm's.
Old Aug 6, 2011 | 05:15 PM
doghouse's Avatar
Old Oct 30, 2011 | 07:49 AM
Levar's Avatar
Veteran: Army
Interesting. The BF272s are smaller and were testing with cooler temperatures only to show slower spool characteristics while having similiar topend performance. This makes me want some GSC S2s even more.
