I'm legal ! (finally)
After a dreaded crackdown of the local COPS pulling me over like every other day (started after I put the 6" letters DYNOFLASH.com across the side of my car) I figured it was time to tone down the exhaust sound and also be ready in case they decided to crawl under my car
so I put in the Ultimate Racing bolt in 3" high flow cat tonight What can I say - an AMAZING unit - very well made - bolted in perfectly and everything lined up 100%. This unit is a direct bolt in replacement for the stock unit NO loss in power which I can feel (however I am currently running a very low boost on pump gas) - this cat is BIG and it seems to flow big So far I did not smell that dreeaded stink smell I used to get when I pulled up to red lights. I did not drive that far yet, but after I drive a few more miles I will report back. Hopefully that smell is gone forever Thanks Ultimate Racing for a great unit that fits good and isnt that costly |
Haha.. At first I thought something completely different..
Welcome to the world of legal performance Al.. :thumbup: I don't think you'll lose much if any power with the cat.. much better off with it.. Did it tone down your exhaust note a bit? I know when I ran my car without the cat for a few days it was quite a bit louder than when I run with the cat. |
yea i think im losing brain cells from breathing the gas fumes at stop signs specialy with the leaded fuel i mix = X
Originally posted by MalibuJack Haha.. At first I thought something completely different.. Welcome to the world of legal performance Al.. :thumbup: I don't think you'll lose much if any power with the cat.. much better off with it.. Did it tone down your exhaust note a bit? I know when I ran my car without the cat for a few days it was quite a bit louder than when I run with the cat. Anyway - hopefully its quiet enough to get them off my ass When you add the big cams, ported head, valves and bigger turbo things start to get very very loud and annoying I like it - it just seems my local cops dont I figure if I quiet it down for a few weeks they will find a new donut shop and maybe some real criminals to annoy |
Originally posted by MrBubbler yea i think im losing brain cells from breathing the gas fumes at stop signs specialy with the leaded fuel i mix = X |
Yeah, I'm not too far behind with the cams, header and head work getting done shortly.. Those damn tickets.. we have a noise ordinance that I used to get nailed on periodically with my exhaust on my other car. I used to do the DB Meter thing and win because it was a threshold thing. I think it was a Babylon town ordinance in my case though.. Since I put my front plate bracket back on, nobody even looks twice at my car.. Its almost unsettling to go unnoticed. hehe..
Just got back from a nice blast up and down the highway
No loss in spool up - no effect on spool up - no effect on power ONLY differnce is the smell is gone 100% and the car is significantly quieter |
The smell of catalyst material is a smell for true men ;). They should make it in a colongue! Ou de catalyst
BTW - looking at my data logs, I'm spooling up just about 100 rpms sooner with the 3" cat than before with a test pipe - simplhy amazing ! {thumbup} Thanks UR
Just for reference, back when I was a bit slower ad run 12.6's at aroun 111 MPH....yeah, **** you, I know I can't drive....I pulled out my high flow 3 inch cat and hollowed it out. The difference, at the drag strip, was completely unnoticeable.
But leaded gas will clog them eventually....thats why i hollowed mine out. |
I would like to know the performance comparison between a 2.5" DP and 3" DP using the HF cat. I have a feeling that boost/spool would be more immediate with the 2.5" DP system while upper end hp may suffer a little...
so did you dyno to see how much hp u lost? Well, it doesnt matter. You have so much hp to spare anyway LOLz. I purposely bought the UR high flow to avoid cops.
Hey AL, good to see your legal!
P.S. running low boost on pump gas now? i thought your bably only saw the high high high octane.......goin more conservative in this colder weather? |
Re: I'm legal ! (finally)
Originally posted by DynoFlash I put in the Ultimate Racing bolt in 3" high flow cat tonight What can I say - an AMAZING unit - very well made - bolted in perfectly and everything lined up 100%. This unit is a direct bolt in replacement for the stock unit Thanks Ultimate Racing for a great unit that fits good and isnt that costly Thanks |
I'm going to put a cat in also...because its the ethical thing to do. Theres no need not to burn off the last bit of fuel and other byproducts before they exit your car. Especially when you can take it in and out very easy on race day.
Buschur has a 3in cat for his clamp system. |
| All times are GMT -7. The time now is 07:03 PM. |
