Wheel bearing
Hi guys, the issue has been getting worse over time and now that I have my daily driver back in action the evo is taking a garage spot to get torn down for some well needed tlc. The problem I am having is a bad wheel bearing howl when turning the wheel left, but when the right side is loaded (wheel turned right) the noise disappears. I am confused as to which bearing to replace and since they are not cheap I don't want to be guessing until I get the right one. I have heard people state that even the rear bearings on a AWD can effect what you hear up front so an input is appreciated! :mitsu::beer:
Very confusing post. If you're turning right, the left side is loaded, not the right.
In any event, a wheel-bearing that is bad enough to howl could easily have slop. Jack the nose and yank on the wheels. It could very well be obvious. Note that the loaded/unloaded test is not 100% accurate. Much better to drive in a circle around a friend and have them listen if you can't figure it out by yanking on wheels. Drive the circle in both directions, of course. |
Originally Posted by Iowa999
(Post 9409952)
Mine makes a similar noise. Problem is is I've had the car up in the air and it didn't move a bit. I replaced my axles thinking that might have been it (it's kind of hard to pinpoint where the noise is coming from).
When I accelerate slowly turning it almost feels like a rubbing/grinding and has a very slight noise (which is not there all the time. I'm just wondering if you're experiencing the same problem. |
Originally Posted by SRTRaceR04
(Post 9410087)
Best way is to put it on a lift, have someone accel slightly and use a long screwdriver or even a mechanics stethascope on the knuckle area.
Good Luck with it. My finding is that when one goes the other is not far behind (within 20,000 miles for me) |
