Wheel bearing
Wheel bearing
Hi guys, the issue has been getting worse over time and now that I have my daily driver back in action the evo is taking a garage spot to get torn down for some well needed tlc. The problem I am having is a bad wheel bearing howl when turning the wheel left, but when the right side is loaded (wheel turned right) the noise disappears. I am confused as to which bearing to replace and since they are not cheap I don't want to be guessing until I get the right one. I have heard people state that even the rear bearings on a AWD can effect what you hear up front so an input is appreciated!
Very confusing post. If you're turning right, the left side is loaded, not the right.
In any event, a wheel-bearing that is bad enough to howl could easily have slop. Jack the nose and yank on the wheels. It could very well be obvious.
Note that the loaded/unloaded test is not 100% accurate. Much better to drive in a circle around a friend and have them listen if you can't figure it out by yanking on wheels. Drive the circle in both directions, of course.
Mine makes a similar noise. Problem is is I've had the car up in the air and it didn't move a bit. I replaced my axles thinking that might have been it (it's kind of hard to pinpoint where the noise is coming from).
When I accelerate slowly turning it almost feels like a rubbing/grinding and has a very slight noise (which is not there all the time. I'm just wondering if you're experiencing the same problem.
