600 AWHP EVO 6 project with your help ( updated)
Hello Everybody
I decided to rebuild my Engine ( EVO 6 with Evo 7 Engine ) with a stroker kit and i hope you to cooperate with me as expertise to choose the parts for the project regarding the specs and the brands .
The car will be for drag races and some weekend crusing .
What I have now is
1050 FIC injectors
Bosch 044 motor sport fuel pump
Fuellab fuel regulator kit
ATS triple carbon clutch
GCS S2 cams and AEM cam gears
Full custom 3’’ exhaust with HKS muffler and no cat
4’’ intercooler
Aftermarket radiator
HKS intake
Halman bro BC
First The turbo will be FP black . with EVo 8 install kit . I’m thinking about O2 housing with external dump tube but still don’t know which downpipe to choose to fit my Evo 6 ?
Then the stroker which one to get the 2.2 or the 2.4 ? . I’m thinking about the manley stroker kit as the prices are moderate , they have the options of 2.2 and 2.4 .
I'll keep taking opinions and expertise knowledge in this thread until I finish the project .
Thanks for your help .
What I have now is
1050 FIC injectors
4’’ intercooler
HKS intake
Halman bro BC
Where are you located? Are you building it yourself, or buying a built engine? There are so many opinions on 'what is best', but most will agree that you are best off going with the closest reputable shop for your needs.
If you live near Buschur, AMS, MAP, CBRD or English Racing then just go there and tell them your goals and listen to their recommendations.
Yes I live in Egypt and here we don't have that big practical experience with stroking Evo Engines to produce such power i'm thinking about . Thats why i'm seeking your help before i order my project components . 99.9 % of the parts i ordered and i'll order are from the states . Thanks and i hope that my dream becomes true ASAP .
Here we go guys ,
Thanks for all who tried to help
The oreder done , thanks for MAperformance for there tech help .
here are the list of the parts i ordered .
Manley Rotating Assembly Kit (7 Bolt 4G63 / 2.4L / 100mm Crank / 150mm Rods)
Selected options:
Crank: Forged 100mm
Rod: 150mm TT I-Beam
Rod Bearing: ACL RACE Series
Main Bearing: ACL RACE Series 97-99 DSM 7 Bolt & Evo
Piston: 4G63 86.0mm / 8.5:1 CR [1.0 mm over]
- OEM Mitsubishi Balance Shaft Elimination Kit.
- AEM Water / Methanol Injection Kit.
- ARP main Studs.
-Mitsubishi OEM Valve Spring Retainer
-Evo VIII & IX OEM Water Pump Kit
-OEM Oil Pump w/ Gasket Mitsubishi Lancer Evolution Evo 8
-OEM Master Gasket Set Mitsubishi Lancer Evolution Evo 8
-Magnus intake manifold
-MAP Stainless Steel O2 Eliminator Downpipe (Evo 8/9)
-MAP Exhaust Manifold Stud & Nut Kit
-Cometic Head Gasket - 0.51mm- 86mm
-Fluidampr Steel Internal Harmonic Balancer (6-1/8" O.D.)
-DBA 4000 Series XS Drilled/Slotted Front Rotors
-Mishimoto Universal Flexible Radiator Hose
-Mitsubishi OEM Oil Jet Check Valve
-Mitsubishi OEM Oil Jet Squirters
-Supertech Complete Valve Seal Kit
-MAP 4G63 High Performance Valves
-Full Blown Cast 70mm Throttle Body
-Innovate DB-Blue Gauge Wideband Kit w/Sensor
-NGK Iridium Spark Plugs / Heat Range 8
-NRG E-PAC Voltage Stabilizer
-Brembo Brake Fluid / SPORT.EVO 500++
wish me luck
I'll keep updating you
Selected options:
Crank: Forged 100mm
- ARP main Studs.
wish me luck
I think i don't need new valve guides ? correct me if i'm wrong please
Also now i'm choosing the Turbo and i'm like 90 % going for the FP black with the install kit
Do you have any better options ?
Thanks Guys for the replies i'll add them to my order .
But really i still need help here regarding the turbo issue .
I want around 600 AWHP on 95 pump gas with meth injection .
which turbo can do it with the fastest spool possible ?
I'm checking the FP black and it only gives this No. on E85 which we don't have here .
Any ideas Please ?
Any ideas Please ?
konstantinosIX
17
Jun 1, 2008 12:32 AM
