crankcase ventilation idea.....
oil pan has a -10 fitting like this.
http://www.streettunedmotorsports.co...bo_fitting.htm how about using a fitting like this and running a line to a catch can? http://www.summitracing.com/parts/EA...0ERL/?rtype=10 |
Will the "pressure" coming out of the engine push the oil from the turbo into the catch can as it might not have a chance to make it to the sump?
Or did you want to use that "T" fitting as a drain from the bottom of the catch can? I'm going to be building a catch can, and run 2x lines directly off the back of the block (where the stock balance shaft sits), as well as the 2x lines off the head. |
Originally Posted by RSMike
(Post 9580281)
You can do this, but you need a one way valve on the bottom of the catch can. You want to avoid drawing up oil from the pan. I have run a similar setup several times in the past with no issue. BTW, this is for a sealed catch can.
Originally Posted by 240Z TwinTurbo
(Post 9580305)
What is a vta can? BTW, if the can is not sealed you lose the ability to draw vacuum on the block via turbo inlet. This is also a reason for the one way valve. |
(Post 9580333)
What is a vta can? http://www.summitracing.com/parts/MOR-85473/ i dont want any chance of the turbo sucking oil so i dont hook anything up to the intake. |
BTW, on the setup shown below for the twinturbo ZR1, I measured 3in of vacuum at the can with 7psi of boost.
http://www.eng.fsu.edu/~jthagard/EVO...ns/f8large.JPG |
Originally Posted by n2oiroc
(Post 9580336)
vent to atmosphere, not sealed it will have a filter on top. like this.
http://www.summitracing.com/parts/MOR-85473/ i dont want any chance of the turbo sucking oil so i dont hook anything up to the intake. http://www.saikoumichi.com/ |
(Post 9580349)
With the proper can sucking into the turbo should not be an issue. I fabricated my own, but you can buy proper sealed catch cans. Otherwise, you will build block pressure.
(Post 9580337)
Cheers, Mike |
Top line went to PCV and bottom was split to the two inlets of the GT3076r turbo's. However, I have seen the venturi ports on the exhaust and understand they are very effective at creating suction. There are a few internet articles on the topic and you can buy the weld on bungs from Summit Racing for cheap. |
