4 inch intake..!
im installing a custom 4 inch intake pipe to my gt35r,will the larger intake cause any problem?
Still using the stock maf?
Originally Posted by wizzo 8
(Post 9587478)
Yes, and you might pick up a few HPs.
N |
Originally Posted by novem
(Post 9589376)
N |
and will i see changes in the AFR's? will it lean or rich?..and do i have to make any adjustments to my flash?
You will go leaner, but depending on your tune, may not be an issue, just monitor your afr's.
Also, how big is the inlet to your gt35?
Originally Posted by BenJ
(Post 9589955)
and the turbo inlet is also 4 inches! its a gt3586r |
The MAF will be the restriction in your intake now since the outlet is just over 3".
Just a heads up you may get some stalling at idle at times. Doesn't happen to everyone though
(Post 9590566)
Waste of time. The MAF is a 3" so no need for a 4" intake. Rip the MAF off and go SD and a 4" intake. You will prob gain close to 20whp just from doing that. Maybe more depending on boost levels.
If you need help setting everything up give me a holla Mikey |
Originally Posted by mikey@spec-ops
(Post 9592415)
waste of time. The maf is a 3" so no need for a 4" intake. Rip the maf off and go sd and a 4" intake. You will prob gain close to 20whp just from doing that. Maybe more depending on boost levels.
If you need help setting everything up give me a holla mikey |
Originally Posted by Mikey@Spec-Ops
(Post 9592415)
If you need help setting everything up give me a holla Mikey and im running a stock ecu with flash will SD work with it? |
