o2 housing question
are all aftermarket o2 housings completely divided?
my o2 housing is divided up until where the flange was welded, but up to the point of where the flange meets the housing in the middle between the 2 openings theres like a gap, i tried looking around but no luck... this is an "ebay" o2 housing that was given to me to replace my current o2 dump that i sold... any and all info will help! thanks! |
No. I have an old one laying around that is not divided at all. I replaced it with an o2 dump. Im not sure what brand it is though since it came on the car when I got it.
thanks for replying!
now...the question is does anyone know if that affects performance/boost? |
anyone?
Pics would help.
i dont have a picture of my o2 housing but this one will sorta help...
http://image.modified.com/f/26095785...o2_housing.jpg the inside of my new o2 housing looks like the stock one on the left. the divider of the wastegate and turbine runners is a little recessed compared to the flange...not like the one on the right where the flange is actually separating the two... bump for some more input! |
if i were to describe it a little more, if the o2 housing was installed, the exhaust gas from the turbine side could go to the wastegate side directly after coming out of the turbo, it is still divided throughout the o2 housing, but right at the top where the flange is, the flange isnt dividing the wastegate and turbine...so the gasses would cross paths before the collector instead of at collector where the downpipe meets the o2 housing...
i hope this makes sense to someone! |
If you match a o2 housin gasket to the o2 housing you will notice that the o2 housing can use some porting. People get rid of the divider because it smooths exhaust path.
-Shane |
Originally Posted by BrunoBoy650
(Post 9653839)
-Shane bump for more help! |
http://i279.photobucket.com/albums/k...o2_housing.jpg
the highlighted part of the flange is not there... hope this clears it up some. |
ttt...
Some people say by not having it divided it can cause turbulence in the 02 housing with the exhaust gases...Others say it won't do anything...I don't think there has ever been a test done to prove anything. It makes sense that it could cause some type of turbulence, but I run an 02 dump & don't have to worry about it at all...
Originally Posted by B.J.@ToxicFab
(Post 9654093)
This o2 housing was free, so i was wondering if i should install this as a permanent replacement or not... one more question...should i use the factory o2 housing gasket? |
Originally Posted by tim85851
(Post 9654272)
Thanks for the input. Im glad i got a vendor/fabricator's point of view.
oh nice! thanks again for replying!
