egt tap blocker
Anyone have some good ideas on how to block a tap for an EGT sensor in a stock manifold?
JB Weld. ;)
Originally Posted by tony_b
(Post 10001170)
JB Weld. ;)
Or just dont even run an egt gauge, a lot of people don't seem to run them anymore.
Originally Posted by boostedwrx
(Post 10001336)
Depends on how much you want to spend then I guess, I've seen used oem manifold go for $50-60, but maybe check with your local exhaust/welding shop to see if they can patch it. The local muffler place by me usually charges me $40 cash for stuff that takes <30 min.
If it were mine, I would drill it out and tap it for a larger plug. Where on the manifold is it?
Originally Posted by blknblubkrdude
(Post 10001414)
Just re-tap it and find the appropriate plug.
If it's truly a stock manifold, I have one kicking around somewhere in my garage, otherwise, drilling and tapping it will work. Just don't do it while it's still on the car.
Originally Posted by THUB
(Post 10002248)
If it's truly a stock manifold...drilling and tapping it will work. Just don't do it while it's still on the car.
Just drill and tap to next larger NPT plug size. First remove catalytic convertor, or test pipe. Be sure to run the motor while you are drilling. This way all metal shards produced during drilling will be blown out the exhaust. There is absolutely no need to remove manifold. Unless you have nothing better to do and you just want to convert what should be a 10 minute job into a five hour ordeal. Just be sure to wear safety goggles. |
^ this
I would re-tap, plug and spot weld the plug.
Weld it. Cast stainless can be mig welded easily.
Personally I don't want to throw all the chips from drilling and tapping through my turbo, and drilling and tapping an exhaust manifold while the car is running seems like a really good way to get badly burned.
Also, I'm pretty sure the stock manifold is iron, not stainless, which means welding is actually pretty difficult. |
