6262 Or Engine Rebuild?
So I'm stumped right now. I have money to do either one. People are saying 6262 on stock block is good to do because the power band is higher up in the RPMS. Considering that I'm eventually going to rebuild my the botom end this year, maybe 4-6 months later would it be smart for me to do a 6262 on a stock block?
do a 6262.. just in the back of your mind remember your motor might go
ive been fine for almost 2 years.
True that it works well on stock block but if you have the money and time to rebuild the engine, I'd start there. You're at a win with either decision.
My opinion is to do the motor first. I would rather ensure that the motor can handle the power reliably, and you will make the most out of the turbo.
Ivey is my tuner so I trust him to make this setup reliable until I do the engine.
Originally Posted by Tpatterson
(Post 10096238)
I'm building my motor from bottom up first, so I know what ever I decide to go with, it will handle it without the fear of putting a window in my block {thumbup} |
Originally Posted by Pssst
(Post 10096329)
I second this...
I'm building my motor from bottom up first, so I know what ever I decide to go with, it will handle it without the fear of putting a window in my block {thumbup} Turning my old block into a table and the 3 of the 4 pistons that still look like pistons into coasters. |
If you are going to build the motor in 4-6 Months down the road then i would do the 6262 now. Just make sure you dont push the car that hard until you build the bottom end that you will be set. I recommend though doing the 6266 instead of the 6262{thumbup}
Motor, then you can have all the fun in the world (high boost) when you add the 6262
Originally Posted by okevolutionVIII
(Post 10096350)
Originally Posted by Evosick2332
(Post 10096367)
Originally Posted by evo8426
(Post 10096375)
^ He wouldnt risk the motor if he keeps it reliable. He said 4-6 months, thats not too long just driving the car conservative. Decent tune on pump gas, car will be still fun on the stock block for awhile. If he goes balls to the wall on the stock block with the 6262 or 6266 then yea he might have a problem. I was making around 450 on a mustang dyno on a Fp Red and it lasted over a year before it blew. And that was constant abuse running 10.50s. I guess he can go either way, but its really just what he feels like doing. Good luck man.
I honestly don't beat on my car. I'll get on it once in awhile, sometimes merging on a low-traffic highway, but other than that I don't launch my car ever.
(Post 10096446)
Originally Posted by cz1
(Post 10096449)
(Post 10096449)
If u have the patience to run around with a turbo capable of making a lot more power than ur tune is giving you than you will probably be ok. If so ur a better man than me! :D |
