how to install evo 8 clutch on a evo 4
can someone please tell me how going about install a act xt clutch kit from a evo 8 onto a evo 4
does it have to be the 2005 evo 8 act xt kit or?? and do i only have to remove the alignment pin dowel? |
any 8/9 clutch + a flywheel from 8/9
grind dowel. thats it. |
Never knew you could use 8 clutch in older evos... good to know
got to change flywheels. they are different sizes.
Originally Posted by 94AWDcoupe
(Post 10156511)
drill the dowel hole???
and yeah just grind the dowel pins so there flush correct? |
which flywheels are lighter from evo 8 or 9?
i want use it on my evo 4 to install evo 8/9 clutch |
Whatever you sort out guys keep the pressure plate light. Evo4's will spin bearings of you look at them the wrong way
Originally Posted by Sirnixalot
(Post 10159101)
I've been running an evo4 engine for the past 8years now and never a problem with crankwalk, oil starvation finally killed it. |
I don't disagree with you on that :lol:
Just saying a 3200# pressure plate with a 4 puck disc on a vehicle with unknown history is probably a bad idea:lol: (not saying that's what the OP wants, just saying :thumbup:) |
