how to install evo 8 clutch on a evo 4
Old May 10, 2012 | 11:01 PM
Canadian Evoguy's Avatar
can someone please tell me how going about install a act xt clutch kit from a evo 8 onto a evo 4
does it have to be the 2005 evo 8 act xt kit or??
and do i only have to remove the alignment pin dowel?
Old May 11, 2012 | 05:11 AM
94AWDcoupe's Avatar
any 8/9 clutch + a flywheel from 8/9
grind dowel.
thats it.
Old May 11, 2012 | 05:44 AM
Brent_si's Avatar
Never knew you could use 8 clutch in older evos... good to know
Old May 11, 2012 | 10:04 AM
stinkbomb's Avatar
got to change flywheels. they are different sizes.
Old May 11, 2012 | 12:03 PM
todd6027's Avatar
grind dowel.
thats it.
as above and the evo 7 also uses same size clutch as 8/9 , you could also drill the dowel hole in the flywheel
Old May 11, 2012 | 03:31 PM
drill the dowel hole???
and yeah just grind the dowel pins so there flush correct?
Old May 12, 2012 | 07:31 AM
Tsula7's Avatar
which flywheels are lighter from evo 8 or 9?
i want use it on my evo 4 to install evo 8/9 clutch
Old May 12, 2012 | 10:50 AM
Sirnixalot's Avatar
Whatever you sort out guys keep the pressure plate light. Evo4's will spin bearings of you look at them the wrong way
Old May 14, 2012 | 01:53 AM
Yogi_B's Avatar
Technically Evo1-3s will also too as they use the same thrust bearing setup as the evo4s.
I've been running an evo4 engine for the past 8years now and never a problem with crankwalk, oil starvation finally killed it.
Old May 14, 2012 | 04:24 AM
Sirnixalot's Avatar
I don't disagree with you on that
Just saying a 3200# pressure plate with a 4 puck disc on a vehicle with unknown history is probably a bad idea (not saying that's what the OP wants, just saying )
4g63girl
Vendor Classifieds
Oct 17, 2016 09:06 AM
Hilux
For Sale - Part Outs
38
Jul 20, 2016 09:41 PM
Hilux
Dec 19, 2014 07:32 AM
High_PSI
141
Jun 15, 2014 05:10 PM
tbaird58
Apr 28, 2014 03:12 AM
