What's wrong with my car!!!!
So today I put an injen intake system on my car. Install went fine. Went for a test run, car spooled up fine and got up to about 4,000 rpms them I heard a pop (probably a back fire) and lost power and acceleration. Car is chugging and smells really rich. It won't go over about 5 mph. Is it the mass air flow sensor? Or something else. Any help would be appreciated.
Sounds like you blew an intercooler pipe.
yup, i would double check the hose and clamps.
I checked all of the connections for the intake system and inter cooler pipes. Didn't see anything wrong.
Originally Posted by Bhubs
(Post 10371167)
I suppose it's also possible that you hit boost cut and the car went into limp mode, but I'm pretty sure you still would have been able to go over 5mph. Did you have the car tuned after the install? P.S. Definitely check the plumbing again before worrying about the tune. |
Ok I'll check them out again. That would explain the sound right before the drop in power. I do not have a tune. The car is stock other then the intake and it has a cheap blow off valve from the previous owner.
Could it be the junk bov that's on it? Would that going bad have the same effect.
I know it has been said, but it sounds like a major boost leak. Check the connections from your intake / bov / UICP again.
(Post 10371202)
Yup. Popped an intercooler pipe. Didn't see it last night. Thanks everyone.
You're welcome!
Glad you resolved the issue, youshould also replace that cheap BOV soon as it will only cause problems for you later. (I'm assuming you have an evo 9 lol under your avatar it says you drive an evo XI and I highly doubt you have the next generation already.) Go back to a stock 9 BOV for now until you decide on a different brand/model.
| All times are GMT -7. The time now is 08:46 AM. |
