What's wrong with my car!!!!
Old Aug 29, 2012 | 06:31 PM
Bhubs's Avatar
So today I put an injen intake system on my car. Install went fine. Went for a test run, car spooled up fine and got up to about 4,000 rpms them I heard a pop (probably a back fire) and lost power and acceleration. Car is chugging and smells really rich. It won't go over about 5 mph. Is it the mass air flow sensor? Or something else. Any help would be appreciated.
Old Aug 29, 2012 | 06:34 PM
Ian0611's Avatar
Sounds like you blew an intercooler pipe.
Old Aug 29, 2012 | 06:37 PM
xxthayxx's Avatar
yup, i would double check the hose and clamps.
Bhubs's Avatar
I checked all of the connections for the intake system and inter cooler pipes. Didn't see anything wrong.
Old Aug 29, 2012 | 06:38 PM
Boostevo58's Avatar
Old Aug 29, 2012 | 06:45 PM
Ian0611's Avatar
Check em again. What you describe is a perfect example of blowing off an intercooler pipe or a massive boost leak. Try actually wiggling the pipes around, don't just look at them. If any of them feel loose or move at all then that's probably where the problem is. If you still can't find the problem do a boost leak test.
I suppose it's also possible that you hit boost cut and the car went into limp mode, but I'm pretty sure you still would have been able to go over 5mph. Did you have the car tuned after the install?
P.S. Definitely check the plumbing again before worrying about the tune.
Old Aug 29, 2012 | 06:48 PM
Bhubs's Avatar
Ok I'll check them out again. That would explain the sound right before the drop in power. I do not have a tune. The car is stock other then the intake and it has a cheap blow off valve from the previous owner.
Old Aug 29, 2012 | 06:52 PM
Bhubs's Avatar
Could it be the junk bov that's on it? Would that going bad have the same effect.
Old Aug 29, 2012 | 07:09 PM
m4tt VIII's Avatar
I know it has been said, but it sounds like a major boost leak. Check the connections from your intake / bov / UICP again.
Old Aug 29, 2012 | 07:18 PM
Ian0611's Avatar
I think it's possible but not likely. Pull it off and see if you're able to move the piston by hand.
Old Aug 30, 2012 | 05:22 AM
Bhubs's Avatar
Yup. Popped an intercooler pipe. Didn't see it last night. Thanks everyone.
Old Aug 30, 2012 | 08:24 AM
Ian0611's Avatar
You're welcome!
Old Aug 30, 2012 | 05:03 PM
EVOeroc's Avatar
Glad you resolved the issue, youshould also replace that cheap BOV soon as it will only cause problems for you later. (I'm assuming you have an evo 9 lol under your avatar it says you drive an evo XI and I highly doubt you have the next generation already.) Go back to a stock 9 BOV for now until you decide on a different brand/model.
Spencer2362
Jul 15, 2016 11:15 AM
SkippygoluckyIV
Nov 15, 2015 12:59 PM
SkippygoluckyIV
Nov 13, 2015 03:31 PM
FTC420
Lancer Troubleshooting
Feb 21, 2011 04:11 PM
RU EVO
Sep 26, 2010 06:03 PM
