Start up problem
Old Jul 13, 2016 | 09:42 PM
Spencer2362's Avatar
Start up problem
Hi everyone, So I just had the weirdest thing happen I just went to start my ralliart today and it wouldn't start. It was turning over fairly fast so I wondered what was up. My accessport had the code ECU there was no numbers or description, also had the code U0167 which is immobilizer error. I reset the ECU and attempted to start it again, nothing. So eventually i just decided to hold it a while then the engine slowly sputtered to life took about 20 seconds to get to idle. Then it was fine the codes went away and starts again fine now. This is the 2nd time this has happend. Is this a sign of something? Or is my car acting weird?.Thank you.
Old Jul 14, 2016 | 05:49 PM
Slee256's Avatar
Replace all your relays if you haven't done so already. Here's the link:
http://www.sspperformance.com/evo-x-...y-package.html
Old Jul 15, 2016 | 11:15 AM
russ72's Avatar
Seems to be a fairly common issue with Ralliarts for some reason. Like last post said change your relays and it should help. I've had issues as well and changed relays, it still happens on occasion but not with the frequency it was before I changed them.
Braydo25
Jul 14, 2010 11:56 AM
geevolution
Dec 31, 2009 05:31 PM
WongFu
AEM EMS
10
Nov 29, 2007 01:28 PM
