AEM EMS Get tuning help for your AEM EMS system.
Cold start Warm start!
Old Nov 23, 2007 | 08:41 AM
WongFu's Avatar
I keep hearing about bad cold starts but I crank over on about 3 cranks when cold but when warm it takes about 8-9 If im lucky Even had a few people come over with jumper cables thinking I need a jump. Anything I can do to improve the warm start up?
Old Nov 23, 2007 | 11:22 AM
awdboosted's Avatar
Ya.. Read this thread. https://www.evolutionm.net/forums/sh...d.php?t=305992
Old Nov 23, 2007 | 11:29 AM
GTVEVO's Avatar
More accurate tuning is your best option, all of your trims need to be spot on for all temps to provide the best startup hot or cold.
Old Nov 23, 2007 | 11:42 AM
ray3328's Avatar
Could it be your starter? I had a similar problem and one day my starter just **** the bed. After installing a new one the problem went away.
Old Nov 23, 2007 | 12:42 PM
awdboosted's Avatar
EMS has a long crank.. cold or hot.. The better your tune is the faster it will start. I'm on a small battery and don't have any starting issues.. just a long crank in the cold.
Old Nov 25, 2007 | 07:17 AM
WongFu's Avatar
No my problem is not the cold start. It starts faster then with the stock ecu when cold but when warmed up it takes alot longer
Old Nov 25, 2007 | 01:00 PM
alpha's Avatar
Hmmm ... Send me your calibration. See if I can do something for you
alpha at brotherzracing . com
Old Nov 27, 2007 | 10:40 AM
awdboosted's Avatar
Then You need to modify the (Start extra Decay graph). In Engine Start/ Advance start/ Start Extra Decay table/ Graph. make sure the car is up to temp, and add or subtract in that area of temp.
Old Nov 28, 2007 | 10:53 AM
dancarroll0283's Avatar
It takes me about 5mins to start my car in the am's its about 30-40 degrees here and im on aem ems.
Old Nov 28, 2007 | 11:30 AM
GTVEVO's Avatar
You probably need more crank injector time and warm up enrichment. As soon as the Stat Sync'd notes being ON it should be trying to fire up.
Old Nov 29, 2007 | 01:28 PM
hostile's Avatar
Warm start is too lean when the warm up enrichment is gone.
You will want to add more cranking fuel, you might have to take down some of the cooler areas of the warm up enrichment table if it starts rich when it is cold.
turbotaloon95
E85 / Ethanol
14
May 7, 2019 03:52 PM
El Boricua
AEM EMS
Oct 8, 2012 12:53 PM
HybridKOOP
Apr 13, 2010 07:45 AM
ITP
Mar 12, 2009 02:36 PM
forbidden color
AEM EMS
13
Aug 1, 2006 06:54 PM
