1st gear grind!!!!!!
I was driving my evo to work, approaching a stop sign. I slowed to a crawl, and upon attempting to put the car in first was rewarded with the most blood-curdling grind I've ever heard. (yes I had the clutch fully depressed) "****" I said to myself. I figured as long as it doesn't happen again I'm not going to worry about it. Well lo and behold, about 2 miles down the road, I go for first again at near idle speed and it grinds just as badly. I have owned 4 manual transmission cars and have NEVER ONCE had a gear grind other than in my evo, which now grinds 2nd, 5th, and 1st!!!! I have also NEVER MISSED A SHIFT IN ALL MY YEARS OF OWNING PERFORMANCE CARS. What the hell is going on here? My car now has:
a vibrating clutch pedal 1st, 2nd, and 5th gear grinds an idle akin to that of a Harley with a misfire (so bad I can't see out the rear view, plus the steering wheel looks like it's going to rattle off ) too many interior rattles to count a misaligned air box a rattling TOB and the best part is... 1016 miles |
Theres lots of topics on here about Mits trannys. To shift into first you have to be completily stopped. Its made that way to prevent wear on the tranny. At least thats the way it is on the OZ Rally Ed. I believe the Evos have the same "problem" though.
I also have a hell of a lot of rattles inside my car. It really pisses me off when I've got my sound system cranked and it sounds like my cars gunna fall apart.
Originally posted by h8yourv8 Theres lots of topics about Mits trannys. To shift into first you have to be completily stopped. Its made that way to prevent wear on the tranny. |
Originally posted by h8yourv8 I also have a hell of a lot of rattles inside my car. It really pisses me off when I've got my sound system cranked and it sounds like my cars gunna fall apart. |
Originally posted by bluevilevo8 Complete stop? First is triple syncro'd!! It's made to grind to prevent wear on the tranny? |
I never down shift into first unless I come to a complete stop. I did that before in traffic, but now just creep in second :(
Originally posted by h8yourv8 Sorry, I meant it's made to not let you down shift to first. You don't want to force it. Thats whats causing the grinding noise. |
With or without double clutch, rev match etc. you shouldn't shift into first unless fully stopped. When you go really really slow you can.
If you wanna force it in, go ahead but please don't post here later how Mitsu tranny sux. You people should really learn some things to prevent breaking your car. As someone else posted - it's funny how only clutches are reported blowing up. |
try some aftermarket tranny fluid
Originally posted by SoR With or without double clutch, rev match etc. you shouldn't shift into first unless fully stopped. When you go really really slow you can. If you wanna force it in, go ahead but please don't post here later how Mitsu tranny sux. You people should really learn some things to prevent breaking your car. As someone else posted - it's funny how only clutches are reported blowing up. I need to learn things to prevent breaking my car? Don't post how mitsu's tranny sucks? Just because you were lucky and don't have tranny problems doesn't mean much... |
Originally posted by Compjoc try some aftermarket tranny fluid |
Originally posted by bluevilevo8 I must have been going 2 mph I need to learn things to prevent breaking my car? Don't post how mitsu's tranny sucks? Just because you were lucky and don't have tranny problems doesn't mean much... I haven't had tranny problems because I drive manual for over 10 years, I have finished driving school where they teach you the basics, I had to pass the state exam (no not US state) and I'm not trying to shift in the 1st gear at 45mph like another member here on evom and also I was gentle on my tranny during break in to allow for proper wear, unlike some smartasses that claim you need to drive it like you stole it to help *break in faster* My $0.02 |
Originally posted by SoR 2mph is ok.. as long as you can shift in with no resistance it's good. I haven't had tranny problems because I drive manual for over 10 years, I have finished driving school where they teach you the basics, I had to pass the state exam (no not US state) and I'm not trying to shift in the 1st gear at 45mph like another member here on evom and also I was gentle on my tranny during break in to allow for proper wear, unlike some smartasses that claim you need to drive it like you stole it to help *break in faster* My $0.02 |
dont put redline mt90 in your tranny. Use some BG Synchroshift. Do a search, trust me.
As far as 1st gear grinding, ive found you have to wait on the gearbox totally. If you rev match before you try to slip it in first, rev match and keep it in neutral for just a tad longer than you think you should. It should slip right in. Ive found its VERY easy to get into first when your mobbin the car. Almost like the synchros are working well when your floggin it. |
