-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Car can't high boost and cuts Rpm (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/670935-car-cant-high-boost-cuts-rpm.html)
KGB_KGB Sep 23, 2013 10:50 AM
Hii,
My. And can't seem to run at high boost which is 2.1 bar and .. It stops at 6k rpm .. As the entire engine switches off and pulls to 7k rpm and switches off..
Anything below 2 bar is ok when I pull .. I pull at 1.7 bar and no problems.
Anyone knows what's wrong . Is it the coil pack ?
JDMekB20 Sep 28, 2013 05:43 AM
Originally Posted by KGB_KGB (Post 10966928)
Hii,
who did you tune with?
PureDrivePerformance Sep 28, 2013 08:40 AM
It sounds like fuel cut. I'd need to see a log and rom, but it can be remedied. It may need to be tuned as it may be seeing higher loads.
Sircuit hero Oct 5, 2013 12:14 PM
I had a similar problem, boost cut at 4000 and anything over 20 lbs, it was a bad waste gate that wasn't holding pressure properly and it was over boosting but the ecu caught it and shut it off. That's why I too thought it was a fuel cut.
Sircuit hero Oct 5, 2013 12:15 PM
Are you running a stand alone ems?
sparky Oct 5, 2013 06:18 PM
At 2.1 bar we are talking approximately 30 PSI, right? What turbo are you running OP?
