Car can't high boost and cuts Rpm
Old Sep 23, 2013 | 10:50 AM
KGB_KGB's Avatar
Hii,
My. And can't seem to run at high boost which is 2.1 bar and .. It stops at 6k rpm .. As the entire engine switches off and pulls to 7k rpm and switches off..
Anything below 2 bar is ok when I pull .. I pull at 1.7 bar and no problems.
Anyone knows what's wrong . Is it the coil pack ?
Old Sep 28, 2013 | 05:43 AM
JDMekB20's Avatar
Originally Posted by KGB_KGB
Hii,
who did you tune with?
Old Sep 28, 2013 | 08:40 AM
PureDrivePerformance's Avatar
It sounds like fuel cut. I'd need to see a log and rom, but it can be remedied. It may need to be tuned as it may be seeing higher loads.
Old Oct 5, 2013 | 12:14 PM
Sircuit hero's Avatar
I had a similar problem, boost cut at 4000 and anything over 20 lbs, it was a bad waste gate that wasn't holding pressure properly and it was over boosting but the ecu caught it and shut it off. That's why I too thought it was a fuel cut.
Old Oct 5, 2013 | 12:15 PM
Are you running a stand alone ems?
Old Oct 5, 2013 | 06:18 PM
sparky's Avatar
At 2.1 bar we are talking approximately 30 PSI, right? What turbo are you running OP?
nspyr
26
Jun 20, 2017 02:08 AM
jmrussell89
Oct 8, 2016 09:29 AM
KGB_KGB
Dec 11, 2015 06:18 AM
audiofan
Sep 26, 2014 05:57 AM
DreamLike1
20
Jul 26, 2006 08:41 PM
