Engine turns over but won't start...
Hey guys,
Figured I'd reach out to the community to get some thoughts... I have a 2.3L Evo 8 tuned on SD, running 1000cc injectors, Walboro 255, a SpoolinUp COP, one range colder plugs, and a relocated full-sized battery (coming up on 3 years old).... I have a lot done, but i think those are probably all of the relevent mods Over the last two weeks the car will crank, but never seems to catch, and will occassionally give me a single pop right at the end. Recently, I have not been daily drive it, and it has been very cold in NJ, so I took a guess that it was the battery getting a little weak and tried to jump it. No luck. After trying to turn it over a couple of times the car started to wreak of gas. I pull the spark plugs to make sure everything was fine with them. Cleaned them off, checked the gap, let the the engine air out a little from the gas smell, and tried again (with the battery jumped off another car, in order to eliminate any variables)... nothing. I checked the fuses (ignition, etc)... nothing. This is my first winter with SD... is this just a "cold start" issue that can be fixed with a tuning adjustment or is there likely something more going on? Thoughts? Thanks, guys! |
How cold was it? Try a heating pad under the oil pan. I was unable to start up my 2.0 with similar fuel mods when it got below -10. I to tried those remedies to no avail, I was able to stick a heat pad under the oil pan for a bit and that helped pop her off after a few turns.
my first guess was the ignition fuse. you sure it's OK? especially if it smells of gas
Originally Posted by MR.Maxwell
(Post 11119412)
Originally Posted by llDemonll
(Post 11119472)
Originally Posted by JScocchio
(Post 11119722)
even on days when it gets a little warmer, 40 degrees, it won't seem to turn over
huge difference between an engine cranking (turning over) but not starting and an engine not cranking |
| All times are GMT -7. The time now is 07:51 AM. |
