EVO IX engine making noise
My car is making a noise like lifters or rods but everything looks ok
the lifters are new (124miles) and the rods bearing like this: https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg timing belt kit changed(250miles) oem parts without serpentine belt the noise is still there any ideas? thanks |
New lifters make even more noise if not bled correctly.
but de noise its exactly the same after changed lifters
is it possible the noise is maked by timing belt tensioner arm?
I have never seen the tensioner making that noise. Sounds to me it's coming from the head. I suggest taking the VC off and go over the lash adjusters one by one.
the lash adjusters are new and i controled when i put them at their place
any update? I have the same problem.
no
I always the noise |
Bleed the lifters using the diesel fuel method outlined in the manual. It fixed my problem.
the lifters are new
tested without oil cap |
Originally Posted by PauloPinho
(Post 11518426)
the lifters are new
but without oil cap the noise doesn't change
Use a long screwdriver or a stethoscope and pin point the noise.
already done
with a stethoscop the noise comes either turbo or downpipe, before turbo no noise |
hi everyone
i made un compression test on my engine, the result: https://cimg2.ibsrv.net/gimg/www.evo...27b6585656.jpg the 1° cylinder is the timing belt side what do you think? |
