EVO IX engine making noise
Old Jun 28, 2015 | 01:04 PM
PauloPinho's Avatar
My car is making a noise like lifters or rods but everything looks ok
the lifters are new (124miles) and the rods bearing like this:
timing belt kit changed(250miles) oem parts
without serpentine belt the noise is still there
any ideas?
thanks
Old Jun 28, 2015 | 01:36 PM
Ev0ikon's Avatar
New lifters make even more noise if not bled correctly.
Old Jun 28, 2015 | 09:52 PM
PauloPinho's Avatar
but de noise its exactly the same after changed lifters
Old Jun 28, 2015 | 10:05 PM
PauloPinho's Avatar
is it possible the noise is maked by timing belt tensioner arm?
Old Jun 29, 2015 | 08:42 AM
Ev0ikon's Avatar
I have never seen the tensioner making that noise. Sounds to me it's coming from the head. I suggest taking the VC off and go over the lash adjusters one by one.
Old Jul 1, 2015 | 03:51 AM
PauloPinho's Avatar
the lash adjusters are new and i controled when i put them at their place
Old Sep 7, 2015 | 05:27 PM
netstat's Avatar
any update? I have the same problem.
Old Oct 6, 2015 | 01:07 PM
PauloPinho's Avatar
no
I always the noise
Old Oct 7, 2015 | 01:58 PM
Project_Broke's Avatar
Bleed the lifters using the diesel fuel method outlined in the manual. It fixed my problem.
Old Oct 8, 2015 | 03:22 AM
PauloPinho's Avatar
the lifters are new
tested without oil cap
Old Oct 8, 2015 | 07:57 AM
Originally Posted by PauloPinho
the lifters are new
Doesn't matter if you didn't bleed them...
Old Oct 8, 2015 | 11:13 AM
PauloPinho's Avatar
but without oil cap the noise doesn't change
Old Oct 9, 2015 | 10:16 AM
Use a long screwdriver or a stethoscope and pin point the noise.
Old Oct 9, 2015 | 11:05 AM
PauloPinho's Avatar
already done
with a stethoscop the noise comes either turbo or downpipe, before turbo no noise
Old Oct 17, 2015 | 08:28 AM
PauloPinho's Avatar
hi everyone
i made un compression test on my engine, the result:
the 1° cylinder is the timing belt side
what do you think?
