Help!!! Installed intercooler and now car won't start
Hey guys, I just installed an xs power intercooler and lower intercooler pipe on my IX. Went to start the car, it would crank, no start. Tried it a few more times, it seems like it wants to turn over but just doesn't. I thought maybe it was the intercooler causing the problem, so switched back over to stock, same thing happens.
I proceeded to do a boost leak test, no boost leaks detected. I've been searching and trying a few different things but no luck. The car was really low on gas, so I thought maybe because it was sitting on ramps, gas wasn't going to the fuel rail, so I put a gallon of gas in there, still nothing! The car was running perfect until the install. Please, any help would be greatly appreciated. Edit: Pulled the following codes: P0340 Camshaft position sensor A P0113 Intake air temperature sensor 1 circuit high (tested pin 1 on MAF harness gets 5v) P2228 Barometric pressure circuit low. (tested pin 4 on MAF harness gets 11.5v) |
Did you unplug anything electrical and forget to plug it back in? The MAF for example...
throw a little more gas in there if it was really low, one gallon probably isn't helping worth a shot anyways.
(Post 11553086)
Originally Posted by ctfpevoVIII
(Post 11553087)
Originally Posted by SpeedLimit55
(Post 11553095)
The gas light was on, it is no longer on with the added gallon of gas. I'm assuming there is at least 2-3 gallons in there now. Could the walbro fuel pump have failed all of the sudden as it was trying to syphon gas while on ramps on a low tank?
New licp isn't hitting the starter by chance is it?
(Post 11553104)
after you added the fuel did the car crank any different? I would also check your fuses to the fuel pump or possibly the ignition, maybe pull out a spark plug to visually see that the plug is getting fuel?
Originally Posted by 06RedRalli
(Post 11553109)
LICP isn't hitting the starter.
Pulled 3 codes from ecu:
P0340 Camshaft position sensor A P0113 Intake air temperature sensor 1 circuit high P2228 Barometric pressure circuit low. Maybe these will help us diagnose it. My question is could these codes have been thrown due to multiple times trying to crank the car to start or are these codes actually pointing to reasons why car is not starting? |
bump. Anyone?
Tried disconnecting the battery for a little bit?
I disconnected the battery yesterday for about a minute, didn't help.
Try disconnecting the negative terminal for 30-45 minutes, while it's disconnected make sure all tbolts are tightened down, make sure the gas cap is closed all the way, maybe check starter fuse/relay?
| All times are GMT -7. The time now is 03:30 PM. |
