boost leak test question
1 Attachment(s)
hey i did a boost leak on my car and i found a found a few leaks.
- J pipe was leaking but i had a new gasket with my evo 9 turbo swap kit(waiting untill i get the 10.5 hotside) -first cupler off intake manifold coudnt hold up --both fixed -throttle body shaft is pissing air like theres no tomorrow -and the last is what would normally be the idle air screw(in other cars).. is it the same on a evo? and i guess there is a gasket in it? happens to be the red # in the pic .. and im guessing the second(lower) red item is the gasket? Attachment 268190 :usflag::usflag::usflag::usflag: |
Yes, there is on o-ring on the idle screw. And you can get upgraded tb shaft seal from mil.spec or STM. They're both vendors on here.
i ordered the mil spec seal last night so i still need a Tb gasket and the idle screw gasket. thanks for the response ill order it today.
That seal from the factory seems to be a common issue mine was leaking there too once the new one went in no issues
